- 14 Oct 2007
- newcastle
All my fans are Corsair so are controlled by the hub, the RGB on the res/card/ram and board are controlled by the board software, which touch wood I haven’t had a problem withHey mate. Just noticed you have the Gigabyte Master and lots of nice RGB going on.
I just cannot get RGB to work on my master properly at all.
The Fusion software either crashes or I can only control the RAM rgb.
I basically just have to keep the colour the default red.
Not a massive issue, just thought I would see if you had any similar experiences?
You have a fairly similar rig to mine.
You may be using a hub or something also.
Thanks,
