- 30 Mar 2017
I so can't be asked to take it out the loop, I might take the back plate off and check the wire its annoying but no really worth the hassle
I know. That's what I thought.
I'd hate to take it all apart and find it not working anyway.
Might not be plugged in on the block properly or dead mobo header or dead rgb.
I'm not that bothered as I got the acetal block where you can't see the water inside. Only the strip on the edge of the gpu lights up.
Would be nice to have it working though.
