I think aorus is discussing not crushing the blacks which happens when you get the wrong black and contrast settings or change too much other settings, I tend to go with the defaults for starters or first time users but it is worth tweaking the brightness and contrast settling once you are comfy.
I use these contrast and brightness slides here:
Brightness:
Contrast:
This way you can make sure you display the correct levels of brightness and contrast and not lose any details in shadows.
Does it actually work on your PC as those are limited values. I guess you can set your TV to Low then view them? I’ll have to test later.
Note however that many people have agreed on 50/85 as being correct. I measured it myself with dedicated test patterns as well. 50 brightness gives the perfect reference black. 85 contrast correctly preserves whiter than white values. There’s no reason to mess with these IMO. Only exception is DV where you can try lowering brightness by 1 to help with raised blacks.
One thing I have tried which seems to work well in shooters is running it in an ultra wide custom resolution of 3840x1600@120Hz
