oh yeah forgot you mentioned it, smart move![]()
Yeah it does seem that the 42 is coming this year but could be later than the rest.. which may sway me towards the 48cx. Why can't they come out nowwwww
Hi all, got my 48cx a week ago but only just set it up with my 3080. Anyone have an issue where when they are on google or other pages on chrome that are mostly white, the screen seems to dim considerably? It doesn't happen on this forum though...
It sounds like your OLED LIGHT is set way too high. The screen has a max overall brightness limit, due to voltage limitations of the power supply - all white pixels at max brightness might be hitting that. It's called ABL, by the way. Totally normal. If you set your OLED LIGHT to a more reasonable value 20-40 range you should never see it.
Thanks, I have it set at 100 based on Rtings and HDTV reccomendations and reducing it has helped. I can always increase it when gaming if needed I guess. Im assuming everyone else has it set to much lower....?
Thanks for the advice, will adjust it down to 50. Are you all running Windows in HDR mode?
Another old school method is and often a more simpler way to deal with it, find a good picture mode you enjoy from the many presets filmmaker is the most accurate and detailed picture out of the box, then simply adjust your OLED to your light conditions (many like 35 or more) these tend to work well in dark room settings.
If you watch more during the day you can also try isf bright for day time and isf dark for night time, isf dark is good very similar to filmmaker mode OLED 35 that I mentioned above.
You can try the above and see how you go, many still prefer Cinema or Cinema home for 4K HDR content since its more tweaked and brighter for that type of content but as I said earlier filmmaker mode is technically meant to be the most accurate.
I have mine set to filmmaker mode and oled 35 for all content but watch in the dark mainly.
100 is for HDR only, which targets 100 nits on average. For SDR content you need to target 100 nits yourself, which on my screen is exactly 30 OLED LIGHT. But you can adjust based on preference. However you will significantly reduce the lifespan of your screen if you leave it on 100 in SDR long term. Around 50-60 is 200 nits, so maybe that is a good compromise for you although 200 nits is very bright imo.
That's all good info but you both only mention the OLED light but miss out on Contrast, Brightness setting level when lowering the light mode. The isf Expert (dark room) oled light is set to 35 but contrast is 85 and brightness is 50
@Spikey
I have been looking at a few ways to use the monitor efficiently by watching this guy which gives some tips especially the power tools software and the Steam motion background. He has done a few videos worth a look in his archive.
https://www.youtube.com/watch?v=CftAs56ar48
Also purchased Fitueyes stand (hope it goes low enough) and 2.1 HDMI cable and a monitor arm for 1 of my Dell 30". Was having second thoughts last night, but since I secured it with the £200 off thought I would go all in and make it work for me. 42" may well have been better, but if this doesn't work out as planned rather have a 48" TV.
People said 30" was to big when I got 2 of them never thought they were. This might be quite different though.
