Watercooled Case Gallery
Hey mate. Just noticed you have the Gigabyte Master and lots of nice RGB going on.
I just cannot get RGB to work on my master properly at all.
The Fusion software either crashes or I can only control the RAM rgb.
I basically just have to keep the colour the default red.
Not a massive issue, just thought I would see if you had any similar experiences?
You have a fairly similar rig to mine.
You may be using a hub or something also.
Thanks,
All my fans are Corsair so are controlled by the hub, the RGB on the res/card/ram and board are controlled by the board software, which touch wood I haven’t had a problem with
upstairs offce WFH pc... Put together from odd-n-sods and spares... Only bought the byski giant cpu block and a couple of cables.
ryzen 5 2600, 1080 (not ti) 32gb ram, 1tb nvme.
EK 360 rad in the front with push pull noctua rad fans (pointing OUT, so it blows across the room).
EK 280 rad in the roof, naked.. The front rads generate enough negative pressure that a lot of air is drawn through it. Can always add external 140's on the top blowing in if needed.
Pure UV lighting:
And some bias lighting from argb bits in the blocks etc
and finally in place, lighting overdrive (too much RGB, gotta take it back to something softer)
Case : Jonsbo MOD1
Specs : 3900X / Red Devil 5700XT / 32G GSkill TridentZ Neo 3600 c16
Cooling : 2 x 360mm slim radiators / Coolermaster Halo fans / EK ZMT tubing / EK Mystic Fog fluid
And full Disco Mode :D
My first water cooled build. Not as good as the rest of them here but I’m pretty happy it all worked
Corsair 500D SE
I9 9900k
Zotac Trinity 3090
All loop components are Corsair HydroX
240 rad up top and 360 at front
Hi guys question When I first built the water cooling, I used 3 Yate Loon 120mm fans. But it turned out to be a bit too loud, so I switched to 3 x Asaka Amber then. Can anybody point me towards the fan that brings Yate back quality but also Asaka calm. Thanks
You'll be wanting Arctic P12 PWM.
Pictures don't really do it justice.
I've been doing more tinkering on this build this wknd.
It's all about the airflow in a case like the H700.
So, I've rigged up another nice 92mm Noctua fan under the GPU.
5950X and 3090 in the same loop with dual 360mm EK radiators.
365W bios on the Palit 3090 OC and the best I can do temp wise is 55c overclocked.
5950X chills in the 60's and 70's under load in games with PBO enabled.
Not amazed with the temps but I think this is the best I can achieve without more serious surgery!
I water cooled the PCH chipset with a block EK do for the Gigabyte Aorus Master X570. Replaced that tiny chipset fan and it doesn't go above 45c now.
I make way too many hardware changes. Might try and leave it alone for a while now!
I’m putting another EK PE 360mm rad at the bottom when I can get hold of a gpu/block to finish the loop , I did just do soft tubing temporary but I’m actually quite liking the look of it now , still I might change to hard tubing cos I want to give it a try for the first time
That lian li case is amazing considering the size of it
oh I was looking at those barrow reservoirs but never seen one before , looks sweet :)
I used all barrow fittings in my build and was very pleased
Did you try putting the tube going round the back of the case like on my build ? I know I nearly changed mine as it’s extremely tight near the radiator
Yours is looking good. That FLT fits nicely.
I tried that but the EK Torque fittings are so thick they didn't fit on the radiator. Ended up having to use extenders and made it look funny.
This is a temporary build anyway. Got this distro plate coming hopefully soon.
