hmm "your computer doesnt meet the updated specifications"
When I put the headset on and connected to laptop, i seem to be having alsorts of issues with the quest tho, cant get it to play with pc correctly tooWhere did you get that message?
Just got mine delivered today and really liking it so far, has a really premium feel to it and it's benchmarking pretty good. Ran Timespy earlier and got 10,260 which is alright in my book. Can also confirm it was the 130w 3070.
Finally have my refund and ready to order, looking at ram and wanted to go 32gb.
Any recommendations?, is the max 3200Mhz on all variants?
Going to order a 1tb WD blue or black as a second drive as well.
Thanks again, that was the video I was watching when I saw about the battery, First time I've had to do anything like that before opening a laptop though, did you disconnect the battery cable also
Quick tip, enable CPU overclocking in the BIOS advanced menu and use Throttlestop to downclock the turbo slightly so your CPU maxes out at around 3,800Mhz. It reduces temps by a good 15-20 degrees with no loss in performance during games. Doing this i get max performance in games with temps not getting higher than 75 degrees on both CPU/GPU.
To get into the advanced BIOS you go into the normal BIOS and press RIGHT CTRL + RIGHT SHIFT + LEFT ALT + F2 at the same time.
Ran a Timespy bench at stock recently for both GPU/CPU as well (without the CPU downclock) and got these results:
Overall - 10,378
GPU - 10,549
CPU - 9,507
thanks for the tip, i've got into the advanced bios but cant find where those options are?
Edit found it, although I’ve never used that software before where to start?
although I'm not home till the 1st.Quick tip, enable CPU overclocking in the BIOS advanced menu and use Throttlestop to downclock the turbo slightly so your CPU maxes out at around 3,800Mhz. It reduces temps by a good 15-20 degrees with no loss in performance during games. Doing this i get max performance in games with temps not getting higher than 75 degrees on both CPU/GPU.
Overall - 10,378
GPU - 10,549
CPU - 9,507
Your timespy is a few hundred more than mine was, but when I applied the above (If i did it correctly) it dropped my score by about 1000 overall
I downclock the CPU a little only if I'm using the laptop usually, playing games, etc.Gotcha, cheers for the screen shots will take a look, surprised by how many settings were in advanced bios
