Not gonna post pictures for now, but you can see what I have posted in show us your car.
But having had the car a couple of days, I have not gone crazy in it due to running it in but some things I can highlight from my short ownership:
Suspension: Coming from an Abarth Competizione the GR Yaris Circuit Pack rides vastly superior, damping is fantastic, so even though its firm it is quite comfy. Maybe the only weakness is over uneven ground it can get a little unsettled but as a total package the suspension seems excellent and of very high quality.
Engine: Seems a lot more potent than test car, still not gone full throttle, maybe that is due to been 2 up versus 3 up, or the fact Toyota put 99 Momentum in the car for delivery and I've since put Vpower in, so 100kg less and maybe test car was running rubbish fuel, plus the air temp is maybe cooler, but I cannot remember how warm or cold it was on my test drive. What I am so impressed by is this little engine has get up and go from very low RPM, it is responsive across the entire rev range, but of course it really does seem to come on song about 3500rpm, but if your in a high gear at 2000rpm and put your foot down, the car picks up. Not redlined mine yet but I've held it at partial throttle to 6000rpm and it gets there with no delay, the test car pulled eager to 7000rpm. The engine on paper should be pretty rubbish, but it drives nothing like a 3cy 1.6 turbo if feels more akin to something bigger. I love the internal noise, so I think exhaust wise I am staying stock unless one comes out that unleashes big power gains, otherwise maybe it just makes sense to look at stuff like downpipe, cats and OPF delete if they yield decent gains, but I need more seat time because right now it seems very adequate, but maybe its just a case of the white cars are the fastest and of course the low kerb weight will be greatly helping with response from the engine.
That is it, averaging 25mpg at present, which I feel is good as I've been on country roads and town driving, no sustained cruising due to running in.
Toyota delivered the car on 38psi all round also, so do check your tyre pressures, dropped them to 32/29 this morning which according to door jam is correct, also disabled the keyless entry as well.
