Caporegime
- 8 Jan 2004
- Rutland
Not sure where the memory latency microcode rumour came from
Probably Dave2150.
Probably Dave2150.
What have they done to it to bring the interconnect latency up to Zen 3 levels?
Don't forget that Rocket Lake was originally designed for their 10nm process, but had to be backported to 14nm. This explains the core count and clock sped regression, but it's entirely possible that the move to 14nm has just made the interconnect traces too long to operate at the speeds they were designed for. It's not the design that's the issue, it's the hatchet job moving to a chunkier node than it was intended for.its brand new architecture and this could just be the normal latency for this design
I would guess so as well though @Robert896r1 is rather adept at memory tuning and even on Z390 with good memory and strong IMC it is possible to tune 3733Mhz to get below ~45ns. My query was more to do with if it was still possible on Rocket Lake or is it like Ryzen 5000 where it is really difficult to get below 50ns.It's not in the 40s at all, latency on the 11700k is mid to high 50s
Thanks for the insight.
It's a little troubling that you are finding this 3733Mhz sync limit which seems quite a retrograde move, though I'm curious as to the reason why it is necessary. Are the memory latencies you are seeing already in the low 40ns when you're at 3733Mhz?
The ability to tune memory without sync limits is the main reason that my tuned 9700K can still hang with my tuned 5800X in some lower threaded applications, though as we are a niche clientele then getting the most performance out of the CPU at stock is probably the priority - similar to what AMD have been doing.
Ryzen ownersI mean if you need to buy special RAM and tweak it for hours who'd do that.![]()
Very interesting. Getting 3733Mhz to C13 is going to be a niche position and that sync limit is going to be mightily disappointing for overclockers.once bios is mature and you can boost ring higher you can daily sub 40 but overall BW will be low. Hopefully at launch when we get architecture breakdowns where we will learn why they went sync but hard to guess now.
11900k sub 40ns. Ring is limited in current asus bios. Even if you loosen up the timings below, you should be able to reclaim that latency loss by boosting ring and stay sub 40ns
Compared to my buddy’s tuned 10900k:
And my 9900k:
We will test SR next on RKL to see what the max frequency sync limit is and whether it’s higher for SR than 3733.
The best I could get my 5800X to is a synced 3800Mhz C14-14-14-31 1T which gives me 57ns. (though also look at that below par Write)
Ah, good to know. I can get my tRAS down to 28 but always left it at 32 as I didn't really find a definite improvement. I generally set tCWL to tCL - 1 but might try your tCWL = tCL. Your tWTR_S/L are impressively at the lowest but your motherboard/memory/IMC can do that. Plus you have the ability to change RTL's and IO-L's whereas I'm at the mercy of how my motherboard trains.@MartinPrince what we learned from extensive testing and data correlation is a lot of these rules are made up and just passed on until they eventually become common place. There's no hard limit for the tras rule or twr = trp x 2 etc. And other things that were encouraged before like lowering tcwl as low as it goes creates a gap that limits the floor on tertiaries ultimately leading to worse performance.
Additional testing summary. Platform is DOA. Get CML if you want Intel.
Goodness, 104degrees on an avx512 workload with almost 300 watts on the 11700.
No need for home heating.
Power Consumption: Hot Hot HOT - Intel Core i7-11700K Review: Blasting Off with Rocket Lake (anandtech.com)
thats 3090 level of heating. wtaf![]()
Really hard to know how Alder Lake well land though, as BIG.little (not big.LITTLE was that's the ARm term - and possibly trademark) is totally new to x86.Yeah looks trash wonder why they even bothered going to the trouble and expense of backporting unless they wanted to hedge bets in case Alderlake was delayed as that should be hopefully much better.
Some good prices now for the 10th gen parts recently though.
