ClockTuner 2.0 for Ryzen... do YOU have a Golden Sample? Post your results here. :)
15 Mar 2007
Asrock X570 PRO motherboard and I ran the diagnostic and it said SILVER, 1325, 4700 Mhz so I and trying it and now it is going up - currently doing 4750! does it keep on going up under tune? I set the diagnostic voltage to 1325 as well. I set the LLC to Level2 because under auto is said it recommended more voltage
8 Jun 2006
leicester
DIAGNOSTIC RESULTS
AMD Ryzen 9 3900X 12-Core Processor
Max temperature: 54.8°
Energy efficient: 3.61
Your CPU is SILVER SAMPLE
Recomended CCX delta: 75
Theoretical maximum CCX delta: 100
Recomended values for overclocking (P1 profile):
Reference voltage: 1250 mV
Reference frequency: 4275 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1350 mV
Reference frequency: 4400 MHz
Recomended values for undervolting:
Reference voltage: 1150 mV
Reference frequency: 4050 MHz
Asetek 670LT 240mm
18 Oct 2002
Swindon
DIAGNOSTIC RESULTS
AMD Ryzen 7 5800X 8-Core Processor
Max temperature: 60.6°
Energy efficient: 3.94
Reference frequency: 4575 MHz
Reference voltage: 1325 mV
Reference frequency: 4650 MHz
Reference voltage: 1125 mV
Reference frequency: 4325 MHz
Corsair H100i AIO
29 Apr 2003
London
DIAGNOSTIC RESULTS
AMD Ryzen 5 3600 6-Core Processor
Max temperature: 63°
Energy efficient: 4.07
Your CPU is PLATINUM SAMPLE
Reference frequency: 4450 MHz
Reference voltage: 1175 mV
Reference frequency: 4300 MHz
On air via Noctua Dh14 + NM AM4 adaptor
20 Jan 2009
Cornwall
DIAGNOSTIC RESULTS
AMD Ryzen 5 5600X 6-Core Processor
Max temperature: 52.6°
Energy efficient: 4.15
Your CPU is GOLDEN SAMPLE
Reference frequency: 4550 MHz
Reference voltage: 1300 mV
Reference frequency: 4775 MHz
Reference voltage: 1025 mV
On air Noctua NH-C14S
Permabanned
12 Sep 2013
Knowhere
ASUS PRIME X470-PRO
BIOS ver. 5837 SMU ver. 56.45.00
TABLE ver. 3672324
DRAM speed 3200 MHz
03/06/2021 06:51:52
I'm using a be quiet Dark Rock Pro 3 CPU Cooler & 2 x 16gb sticks of DDR4 on an X470 board.
I'm not an overclocker so I'll be running my memory at it's XMP rating of 3200mhz along with the stock CPU,
Before swapping over to the new CPU I did a number of benches with the 2700X I've had for the last 3(ish) years so I can compare the results with the 5800X once I'd fitted it, It's more of a real world test as all the testers tend to use high end GPU's whereas my GPU is a 5700 XT.
07:19:50: Step# 23. Diagnostic VID: 1055 mV
07:19:51: Stress test 1 started...
07:20:25: Stress test stopped.
07:20:27: Stress test 2 started...
07:21:01: Stress test stopped.
07:21:02: Step# 24. Diagnostic VID: 1049 mV
07:21:03: Stress test 1 started...
07:21:20: Thread# 4 fall down!
07:21:20: Stress test stopped.
07:21:21: Step# 25. Diagnostic VID: 1055 mV
DIAGNOSTIC RESULTS
CPU VID: 1055
CPU TEL: 1038
Max temperature: 58.8°
Energy efficient: 4.21
Reference frequency: 4700 MHz
Reference frequency: 4800 MHz
Reference frequency: 4475 MHz
14 Mar 2003
First time I ever ran it I got:
DIAGNOSTIC RESULTS
Max temperature: 59.8°
Energy efficient: 3.76
Your CPU is BRONZE SAMPLE
Reference frequency: 4225 MHz
The second time it said:
DIAGNOSTIC RESULTS
Max temperature: 61.4°
Reference frequency: 4675 MHz
Reference frequency: 4750 MHz
Reference frequency: 4425 MHz
Either way, I think mines a bit of a dud. Doesn't like any extra mhz at all or it throws a hissy fit so it only does 4850mhz max with pbo. Using CTR to tune actually settled on a 1250mv/4700mhz all core load overclock. Adding more voltage doesn't net any more out of the chip. Using a Noctua NH-U14S with two fans.
6 Feb 2019
I cant even run cinbenench, this happens
8:38:35 pm: Cinebench stopped!
PPT limit reached! 258.8W
8:38:58 pm: Cinebench stopped!
PPT limit reached! 247.3W
Is this because im running with PBO on? does the CPU have to be stock?
Caporegime
OP
8 Sep 2005
Utopia
PBO is enabled by stock... have you done any manual tweaking of settings?
Ok it runs if I set the cpu back to stock
What is a Platinum sample? Is that good or bad?
Look at other peoples results and compare at each voltage. Looks worse than Bronze though.
6 Feb 2019
I changed it back to stock motherboard default bios)
i think this software is buggy cause the numbers don't make sense - when I run the tune function it tries to find the max stable clocks and says that the second CCX can only handle 4000mhz at 1.3v but actually it can do 4.3ghz with that voltage, I know cause I've done it
Caporegime
OP
8 Sep 2005
Utopia
Ahh I misread which CPU you had, so for 16 cores I guess your results are good although if a test fails it is due to instability and likely caused by manual BIOS settings. The tool isn't 100% accurate obviously, it's just a "best endeavours" based on the limited testing it performs and is no substitute for manual tweaking.
6 Feb 2019
I had to set it back to stock to make it work. The tool seems to apply PPT limits based on processor model, for the 5950x its 120w, as long as it goes above that it stops any tests. I had manual PBO settings that allowed the 5950x to pull 260w
Changing back to stock with the cooler weather around here made me realise how much temps change between stock and overclocked, its massive. Running cinebench with PBO manual settings = 80c, running cinebench with stock defaults = 45 to 50c
The all core clocks for a stock 5950x is pathetic though thats why I can justify staying stock, it runs at just 3.75ghz in cinebench, but with manual PBO it runs between 4.35 and 4.5ghz
6 Feb 2019
I would have thought the Platinum rating would mean it's better than Gold, similar to how the ratings are used with PSU's.
Yeah, however its only showing platinum because the test thinks the CPU is running at 0watt and I dont know why. Based on the clocks the cpu looks more like a bronze sample, only showing platinum because it cant find how much power the cpu is using on this test
Permabanned
12 Sep 2013
Knowhere
That's a shame, Do you manually overclock yours then? After watching a few reviews and primarily using my PC for browsing & Gaming I can't see the point in doing so for me, From what I've seen in reviews for gaming there's normally very little to gain & in some games it can hurt performance.
