- 18 Feb 2007
- London
For most games that support FPS boost and/or auto HDR, the feature is on by default. However, for some games, you’ll need to enable it manually. To do so, go into the Manage game section of any title, and then select Compatibility options.
To enable FPS boost, simply check the box. If you prefer to disable FPS boost and play the game in its original form, uncheck the box.
Thats from xbox support, not checked myself.
Thanks will take a look later, don't think I have any installed though that make use of it.
