Caporegime
- 18 Oct 2002
I'd take a slightly warmer system than hearing the coil whine any day
Absolutely, it's not too warm anyway.I'd take a slightly warmer system than hearing the coil whine any day![]()
£699 with delivery is big jump in price. Sux that this will be the new norm
Jesus did you see the price of the ASRock one today?
I think its stayed so long in stock for this very reason but shocking prices happening.
If you are inside DSR period then you can reject it, but OCUK may do a restocking fee. Or you could try an RMA but the fact coil whine is reduced with an FPS cap is normal on most GPU and would not be seen as a fault.
In 20+ years I have never had a GPU regardless of perceived quality/price that did not have some coil whine with uncapped FPS. Some are worse than others to be fair, but they all had it and only the really bad ones can be heard over normal fan noise.
That 6700xt fighter is turning out to be a good little card for the money when compared to other cards with those very over the top coolers which really do not make much difference on 6700xt Gpu die`s when it comes to FPS and when you look at pricing you are paying £200 or more just for the coolers.
I think it is too. I paid £458.31 for my Asus ROG Strix Vega 64 back in June 2018. Just shy of 3 years nearly, and I've grabbed a 6700XT for £449.99 (sold my Vega 64 to a family member for £200). So in reality I've grabbed a 6700XT which is performing really well (I was shocked at how small it was compared to the Vega 64) for just £249.99.
https://i.~ibb.co~/PrJRy11/GPUSize1.jpg
https://i.~ibb.co~/1s0wtCj/GPUSize2.jpg
honestly it could be your PSU, i would if possible try the GPU on another system to rule that option out.
I’m thinking it might be. I’ve got a Corsair RM750x which is less than 6 months old but it’s happened with both cards. Might try a new one of those before RMA’ing it.
I have the same Card and PSU and have not noticed any whine , can you try the card in another pc ? or try another psu ?
I honestly thought a cat was trapped inside my case - it does go away when warm though
You checked that their wasn't, right?
Might not help or be feasible given monitor or usage but have you tried FRTC under the advanced options and set it to max framerate of your monitor ?
This is something I used on my vega 56 initially and that stopped the whine although after some use it disappeared on its own.
