Permabanned
- 9 Aug 2008
Anyone upgraded yet?
ofc.
It sorted itself out and now says no updates, shows the latest in system info.
Hello - date peculiarity with 21H1 install.
Installed as an optional update and shows on list as 21H1 - installed 21/5/21, BUT on the Windows update page "OS build Info" link it shows as installed on 24/10/20 which was the date the last major update (20H2) was installed. Peculiar?
Anybody else found this please? Mel
I did a fresh ISO install so mine says how it should. It probably hasn't updated but if you do winver and it shows 21H1 don't worry about the date it will catch up next updates.
You are fine thenWinver shows 21H1 (OS build 19043.985).
Notepad++.The notepads supposedly going to the Store with 21H2, so will hjave to be reisntalled from there, wtf!.
The notepads supposedly going to the Store with 21H2, so it will have to be reinstalled from there, wtf!.
Bye Bye notey.![]()
Are there still people who don't use Notepad++ or other alternatives?
