“If you were a proper anorak and you look at our team’s performance at this track over the last several seasons,” pointed out Merc’s tech director James Allison, “even in years we’ve won championships with some ease, we’ve nevertheless struggled here and although we have generally been on a path that has delivered a car that is really a sort of broad-sworded weapon that you can attack most tracks with, here has been a significant Achilles heel.
Mercedes doesn’t have a specific Monaco wing. At Barcelona it was already running its biggest wing – and that was the one on the car here. The Mercedes cannot be further ramped-up at the back for a slow circuit in the way the high-rake Red Bull (and Ferrari) can. That way, they can increase the downforce by the greater angle of attack. There’s a physical limitation preventing that with the Mercedes – and its aerodynamics are not appropriately configured for that anyway.
The longer wheelbase will not help on slow corners. The load transfer on the front tyres, other things being equal, will be slower to build. On a circuit which puts such low energy – both chemical and mechanical – into the tyres, that might give you trouble generating tyre temperatures. The corner can be essentially over by the time the temperatures are getting into their sweet spot. Especially on a cool day like Saturday. “It’s always about tyre temperature here for us,” said Hamilton. “The tyres were just not working the whole way through qualifying.”
I think any team would take the loss at Monaco if it means they can win at every other track.
This also begs the question, why is it the ‘softer’ material is the hub, not the nut? Surely the nut is the easier item to replace so if there’s any cross threading the nut is the part that gets damaged so if it can be removed a new nut, perhaps integrated into the wheel, can be put back on?
Merc will do better next race, it's similar in type to Monaco but not as extreme and then get back on form once the tracks start to favour their car. The only real concern is the team working under increased pressure and not over compensating.
They do often have issues around Monaco, but it all equals out once they hit the more typical tracks. Maybe they put too much pressure on themselves to perform at Monaco and mistakes start to creep in making it even worse the next season.
And?Since 2014, and prior to this race, Lewis has finished outside of the podium 18 times, of those he won the following race on 14 occasions.
Let's not get carried away, if they hadn't botched strategy and had that weird problem with Bottas's right nut, then they would have come away with good points. Leclerc's accident and then dropping out hurt them too, stopping Lewis from setting a good lap (he was slow anyway, but he could have done better) and handing Max an extra 7 points on a plate.
Apparently Bottas’ wheel is STILL on the car and can’t be removed until they get back to the factory.
