Thanks. Thought it might be. Definitely something I want to play once it’s less buggy if ever.Knowing Bug, Star Citizen.
Bug has been suggesting I give it a try. Probably will at some point as I like 'space stuff' in general and it does look nice graphically.Thanks. Thought it might be. Definitely something I want to play once it’s less buggy if ever.![]()
I have heard this a lot but this is not true for normal NPCs in Cyberpunk. They are still as floaty as hell. The only thing that grabs one's attention is reflections in certain areas but the game still has that plastic feeling for me. If we are talking about Metro EE; despite its numerous flaws it has one of the best and noticeable implementations of RT.I've always stuggled to be drawn in to 3D games due to the cardboard cutout look, with floating NPCs/Objects. I wasn't blown away by CP2077 as such, but I did at last feel I was looking at a 3D scene. At one point I forgot I had left it running instead thinking I had left the TV on. NPCs looked grounded, lights projected their shape rather than a point and the shadows were spot on.
I can see more people using it for single player, but for multi? Not a chance. That's all about the fps, not having 64 players gathered around a Bush arguing wether the ray traced shadow is more aesthetically pleasing than the rasterized shadow.
Ray Traced foreheads, colour me interested.Least if it was hitman and it had mp then everyone be comparing the rt on his shiny spot on his bald head if its realistic.
Don't say it out loud, or you will be attacked by people who scream "NO NEED NATIVE!!! NATIVE RESOLUTION IS SATAN'S SPAWN!! IT IS UNNECESSARY TO CHASE NATIVE 4K!! COMPUTATIONAL POWER IS WASTED ON RES!"When a game - CP2077, needs to be played at a much lower resolution with DXR enabled, then the hardware isnt up to the job (as HUB says weekly). 1080p upscaling is just that - upscaling. Call it what you will, DLSS/FSR, its just fakery.
Completely agree with the point about the lack of clean, sharp image in games these days. Taking into account TAA, post-processing stuff, and now with the advent of DLSS/FSR it seems that the days of proper native resolution graphics are numbered.Don't say it out loud, or you will be attacked by people who scream "NO NEED NATIVE!!! NATIVE RESOLUTION IS SATAN'S SPAWN!! IT IS UNNECESSARY TO CHASE NATIVE 4K!! COMPUTATIONAL POWER IS WASTED ON RES!"
TBH, I prefer native, sharp and clear 4K image over 960p-1440p RT'ed image. Games these days just look so blurry that the 4K is a minimum for me to get acceptable sharpness. Everyone has their own preferences, but native 4K is something else when it comes to image quality.
It seems like some people just hate native 4k and want to push other graphical aspects instead... RT is one of them... Not quite sure I'm liking the direction.
My ambition remains that I hope to always have enough GPU power that I never need to use either DLSS or FSR.
I guess it's the satisfaction gained from knowing you have the grunt to conquer the ultimate resolutions and image quality settings. I game at 75 FPS and expect to be able to achieve that if I've forked out for a top tier card. I'd be disappointed if I had to utilise a trick to be able to obtain satisfactory performance levels, just as I am when I have to lower any graphical settings.Why? What if solutions look no different unless viewed under a microscope?
Looked the same and almost the same (even if it is 99% ) are two different things. If upscaling can give an objectively better image than native for all scenarios then people like me would switch to it. Until then it's equivalent to lowering your settings.If it looked the same youd likely use it. Because then you could say your top tier card can do 150fps while others do 100![]()
Not on principle but quality. If I wanted higher framerates with lower settings I wouldn't be aiming for Ultra settings with all the bells and whistles turned on. Ideally, I want both and I can compromise if I have no choice but I can't lie to myself that I am getting the best possible IQ with DLSS/FSR.So if it offered double the framerate and looked 99% the same you'd choose to stick to a crap framerate out of principle lol.
The picture in my head of that scenario playing out is funnier than it really should be.
The irony being that people will turn on DLSS or FSR because "you need a microscope to see the difference"; but will leave ultra quality (or what ever the highest graphical setting is) turned on even though "you need a microscope to see the difference" between the two highest presets.Why? What if solutions look no different unless viewed under a microscope?
