The RT Related Games, Benchmarks, Software, Etc Thread.
Status
Not open for further replies.
Just tried it in Metro Exodus Enhanced, which im playing on Quality DLSS, and it does look better (looked sharper), so switched it to Peformance, to see what that looked like that, and it still looked great, just a very slight drop in sharpness (thought the drop would have been bigger), so then i tried the Ultra Performance, and that was more noticeable though, less sharp, bit blurry.
just had a look at those comparisons, im really surprised Nvidia doesn't toot its horn more. DLSS 2.2 is a significant image quality improvement over 2.1, they should be celebrating
I think they'll be tooting that horn on AMDs FSR release day :D
Is battlefield 2042 going to be a nvidia sponsored title then?
Looks like the guardians of the galaxy might be too or at least it most likely will have dlss in it anyway since avengers added it.
And the persistence with rtx, looks rather nice:
Very brief at the end, but a good example of the very natural soft shadows that ray-tracing provides
Looks like you were right @JediFragger
NVIDIA DLSS plugin for Unreal Engine 5 is now available, also coming to Unity 21.2 and Linux through Valve’s Proton
NVIDIA pushes DLSS adoption across the market, compares quality to upscaling/sharpening methods
Just a day ahead of the AMD FidelityFX Super Resolution launch, NVIDIA wants to steal the spotlight from its competitors.
Over 57 games will now support NVIDIA Deep Learning Super Sampling (DLSS) technology, a super-resolution technique that makes use of artificial intelligence boosted by NVIDIA Tensor cores. This technology is now supported by NVIDIA Turing (RTX 20) as well as Ampere series (RTX 30) graphics cards. Today NVIDIA confirmed that other games will receive support for DLSS starting with LEGO Builder’s Journey on June 22nd. The DLSS-supported library will also extend with Doom Eternal on June 29th and Red Dead Redemption 2 at some point in the future.
Earlier this month game studios have enabled NVIDIA DLSS support in RainbowSix Siege (the first game to feature DLSS 2.2), as well as No Man’s Sky and The Persistence. NVIDIA also revealed that on July 1st a survival game Rust will also receive DLSS support.
https://videocardz.com/newz/nvidia-...to-unity-21-2-and-linux-through-valves-proton
I don't think that is going to be an RTX title? It's going to support GI and reflections even on cards that don't have RT hardware, so a cut down RT implementation again.
Got the impression they will be scaling so older/weaker gpus would still be able to play with decent perf. either way should still be very impressive being massive/snowdrop engine.
I must admit I've not looked at Ubisoft since they left Steam. I think the last Snowdrop title I played was The Division.
Status
