All I can say is 3rd party start menu's, please hurry up, M$ get worse with the design.
Honestly, for me using Bypass.reg is just as simple and it beats messing around with different images. I'm not saying my way is better than yours, or vice-versa - but it's quick and easy to import a .reg file from a command prompt within the installer.It's easy to bypass all this TPM and minimum spec nonsense, just replace the install.esd/install.wim on a Windows 10 install USB with the install.esd from the Windows 11 Pro Build 22000.51 x64 ISO. Then simply use the Win 10 installer. (I used Ghost Spectre 2009.21H1.X64.GHOSTSPECTRE.(W).ISO)
(No need to convert the install.esd/install.wim like some online guides suggest!)
<SNIP>
StartIsBack++ should be compatible soon if not already (not had a chance to test it)
Latest build:
Yeah I hope there will be a way to get the win7 startmenu on 11
Didn't work when I tried the latest version, it installs but just cause explorer.exe to crash. It crashes then auto restarts and crashes again forever in a loop. Windows works fine once its uninstalled though. Hopefully there will be a Windows 11 version as I use it all the time on 10 as it quicker to use than the default one but I use both start menus equally as they both have their pros and cons.
I have used Netflix/Prime and YouTube without issues.Anyone had issues with videos/streaming? I'm on 900mb dl and youtube buffering on 720P videos/can't even watch a discord stream
You do realize that Microsoft has stripped the requirements in the first release candidate don't you?
I managed tweak to force Windows 11 as the Windows 10 via regeditor. Much better!
