- 13 Jun 2016
- UK
Level1Techs did a video on it very recently!Been looking up the Pi-KVM, and could be a great use for my Pi 4
Hopefully! The Pi is running LibreElec at the moment, with the TVHeadend server plugin for Kodi. Ultimately I would like to get Plex working as the DVRYou should also be able to integrate TVHeadend into Plex (or Emby), and then use them as the TVGuide/DVR, and stream to any device around your house that has a Plex client etc
I like the project, pretty cool but my immediate thought was why not buy POE HATs for each of the PIs and replace the internal switch with a POE one, something like the TP-Link TL-SG1005P is cheap, albeit I appreciate this alternative would mean 4 Pis instead of 5? Cooling could then be provided by fans running off the GPIO pins on the Pis?Came across this, https://github.com/pawl/raspberry-pi-1u-server#raspberry-pi-1u-server
Pretty cool.
Yeah good point, not sure if there was a particular reason he didn’t go that route.I like the project, pretty cool but my immediate thought was why not buy POE HATs for each of the PIs and replace the internal switch with a POE one, something like the TP-Link TL-SG1005P is cheap, albeit I appreciate this alternative would mean 4 Pis instead of 5? Cooling could then be provided by fans running off the GPIO pins on the Pis?
Either way, it's a very cool projectYeah good point, not sure if there was a particular reason he didn’t go that route.
I've not done it myself outside of tvheadend but it's definitely possible. I guess you could run tvheadend without a tuner and just run the EPG grabber. That would give you EPG data and a html interface that you could access to see the EPG.
Alternatively, if you google "epg grabber" you will find things like WebGrab+Plus that collect EPG data as xml from various tv guide sites using their apis.
You should also be able to find a suitable EPG viewer such as XML EPG Viewer if that is required.
