Yep. Great price, though for 4K I think the extra oomph provided by the 3070 is useful to keep things above 60, but not a big deal, nothing a bit of tweaking in the settings won't solve![]()
Unless you play Cyberpunk with ray tracing enabled. FPS hovers around 40-50 @ 1440p DLSS quality, rtx shadows disabled, depending where you are. I hope CD Red gets their kickbacks as it was the reason I upgraded my living room box..
Interestingly @ 4k RTX 3070 completely chokes even if you run it at DLSS performance or ultra performance, I guess that 8GB just runs out at 4k + RTX even if the native resolution is the same with 1440p that runs fine (to some values of fine).
. The AIBs run much more quiet at full load.
