It’s weird, there doesn’t seem a reason for the stutters. It’s smooth one second, but then stutters randomly and I frequently. It could be because I’m downloading the world updates at the same time.
Doesn't it stream map data while you're flying? I presume with the load on the servers it just can't keep up right now.
. I'm tempted to get a Thrustmaster Hotas, anyone using one? anyone know if the TM Hotas X will work on Xbox? ( the one meant for the Xbox is called the Hotas One ), the X is PC/USB but can be picked up for about £53.
