Hmm Crysis 2 and Crysis 3 says otherwise. Crytek isn't exactly a great dev when it comes to their single player effort.
We will get Crysis 4 when Half Life 3 appears.
I fail to see why you can't just change the "file reference" in your example, when installing an update.Depends a bit on the de-duplicating process involved - when I read about it awhile back it seemed more like an automated process taken away from the game developer - the new material seems to suggest it is something the developer has more control over.
Duplicated data isn't always about reducing time spent seeking data on the HDD sometimes it is used for instance so as to stage the game for a later expansion or content update where some of the duplicates will be swapped out later - but if the developer has some control over that then it is a non-issue.
let's hope Intel brings a better open source upscaling because FSR is already everywhere you look, even on emulators. In 3 months it spread faster than the virus.
FSR v1.0 is everywhere.let's hope Intel brings a better open source upscaling because FSR is already everywhere you look, even on emulators. In 3 months it spread faster than the virus.
I saw this and i was reminded of the earlier bickering in this thread.
Click me
Click me
I think the mods should ban you for butchering that quoteDoesn't matter if you win by a foot or a mile, history only remembers the winner baby!![]()
They call them consoles cos you need somebody to console you after you've tried one... !!
