- 12 Feb 2014
- Somewhere Only We Know
Gigabyte are about to release X570S motherboards, all passive cooled: Gigabyte launches AMD X570S Series Motherboards | bit-tech.net
Has anyone else noticed that they've removed Dual Bios from the 'S' version of the X570 Master (if the specs page is correct?
https://www.gigabyte.com/Motherboard/X570S-AORUS-MASTER-rev-10/sp#sp
Under the BIOS section in the specs list it says 1x256 Mbit flash vs 2x128 Mbit flash on the old Master. This is a big retrograde step and has been done sneakily so people don't notice; I certainly assumed that all higher end Gigabyte boards would have Dual BIOS, particularly if they are based on a model that already does have it.
You can disable it, thankfully (although 99.9% of people don't study the manual in great detail and wouldn't know that it exists). I suppose Gigabyte think they are being helpfulI don't really think dual bios is needed anymore now that you are able to flash most upper end boards without even so much as a CPU installed to recover from a bad flash, I've never used the dual bios function on my master.
But as for building the bloatware app into the bios, if that option can't be disabled and they add it into future boards, then it's bye bye gigabyte for me, that app centre is nearly as bad as MSI dragon centre.
.Where on the board do you think the rattling is coming from? Have you screwed the board into the case securely using all nine screws (do not overtighten)? If you change the PCH fan profile from balanced to silent in the BIOS does it stop? What is the temperature of the PCH/chipset and what RPM is the fan running at?Hi all, not sure if this is the right place to ask, my x570 master is making some strange rattling noise, even when my case fans at max speed, still can hear the rattling noise, did it happen to any of you?
hey folks, relatively new owner, been running for a few months now, and having major issues with the PCH fan lately, gotten obnoxiusly loud even though temps aren't that high even on the silent preset. the bios control of the fan seems very basic with nothing but presets that give you no real control over the fan curve, anyone got any tips on how to fix this?
Hi folks.
Got myself a shiny new 3080 FE. Im still on the F11 bios (https://www.gigabyte.com/Motherboard/X570-AORUS-MASTER-rev-10/support#support-dl-bios)
Any reason to jump all the way to the latest bios?
Card seems to be working fine.
I see some stuff about resizable bar, but not sure if I get anything with that when running a 3900 processor. I need to read up. Any advice appreciated.
Thanks mate. It's a 3900 non X. Not sure if that matters.Yes resize bar will work for you. I was using it with my 3700x.
Just know you will also have to flash your 3080 FE as well.
But that is pretty easy. You download a little tool from Nvidia that does it for you.
I'll read up on it. Is it earth shattering? Worried about having a non working system.
Sorry. I feel like you've suggested I do something but I don't know why.Worse case scenario is you turn it off in the bios.
I think there are some bios prerequisites which I can remember of the top of my head.
Best to create a thread on that topic and people will chime in which with you need to do.
Create a topic for what? Updating the mobo bios or the video bios?
Ah ok cool.How to enable rebar on the GPU.
Ah ok cool.
So first things first I'll do the mobo. Presume the latest doesn't have any gremlins? Did a quick search and no one seems to be moaning.
Haha too late. Done it. Presume I can flash an older one.Just a note don't use bios with a letter after them like F35c
I have a gigabyte bios also and the latest has a c which means its a beta.
Stable bioses are the ones which are just a number like F35.
