i know right?Haha, this is comedy gold. It’s like watching a pair clowns torturing each other.
Yes. If by calling them out you mean getting your LeFuryOnThe ability for some of these clowns to twist things so tightly to suit any argument, always to the point of contradiction, is truly shocking. And yet if you call them out on such bovine manure you get a suspension.
You have no idea how much that name sticking around makes this jaded old fart smileYes. If by calling them out you mean getting your LeFuryOn![]()
You have no idea how much that name sticking around makes this jaded old fart smile![]()
Which 10nm CPUs are we looking at as Alderlake seems to be faster than Ryzen 5000 core for core?
How is it twice as fast core for core though when the example your showing is a 4/8 vs a 8/16?
We know Intel has issues with power consumption which is why they are going big little so they can scale up the core count without hugely increasing power.
So AMD's CPUs are superior to Intel purely because of the node advantage. Yet, AMD's GPUs are only on par, and sometimes behind, Nvidia's GPUs despite having the same node advantage. And, Intel's 10nm SuperFin is inferior to TSMC's 7nm - therefore AMD still have the node advantage - but Alder Lake is gonna stomp all over Zen 3.
But architecture has zero to do with anything
Really?
10nm 11800h says hello.![]()
AMDs CPUs scale better with lower power while Intels scale better with higher power, a proper comparison would be the 11800H vs 5800H or 5900HX and with all using the same 45w power. SC is about equal with the 5900HX while AMD is a bit faster in multicore as SMT is better than HT.Yeah ok, 45 Watts, whats its performance, no seriously its already using 3X the power, is it 3X faster than AMD's 8 core 15 Watt CPU? I'm going to stick my neck on the line and say that it isn't, that its no faster than AMD's 15 Watt part, i think i'm pretty safe in keeping my head.
He is correct in that AMD's implementation of SMT is better than Intel's. So he does pay some kind of attention.Wow,
you’re still posting nonsense.
And also that intel scales better with more power while AMDs performance scaling starts to drop off around 55wHe is correct in that AMD's implementation of SMT is better than Intel's. So he does pay some kind of attention.
Thats why I included the 5900HX which according to AMD has a default TDP of 45w.This is a disingenuous argument, its not in good faith, pushing a 35 Watt CPU that already scores higher than a competitors 45 Watt CPU and then make the calculation again is just normalising inefficiency curves, a 105 Watt Ryzen 5800X score 60% higher than a 45 Watt 11800H, you could make the argument the Intel CPU has a very similar PPW to the AMD chip and you would be right, just as you are right that running the 5800H at the same power level as the 11800H the 5800H may only score about 20% higher and therefore only has about 20% higher PPW.
And with that one might say yes Intel scale better at higher power, so lets turn that round, why not push the 11800H to the same level of performance as the 5800X, how much power is it using? 105 Watts? do you think? I don't, i think its more like 200 to 300 Watts and that's the reality with ALL these chips when you push them that far outside of the most power efficient zone.
Probably because AMD boost algorithm is more sensitive to thermals so start dropping clocks as temps increase.Have you ever considered why…
The 5900HX is a default TDP of 35 Watts
