Yeah absolutely. I’ve gone from a 12 Pro to a 13 Pro Max and the weight is very noticeable. It’s not too bad though, but I’m definitely aware of it.
I've gone from the 12 Pro to 13 Pro and can definitely feel the extra weight.
Yeah this 13 pro max is a brick![]()
Has anyone gone from regular 12 to 13 Pro?
I always said if I changed at all I'd go Pro Max just to make it seem more worth my while what with the size upgrade and everything. However, I'm not sure the extra weight would make it a good move after all.
Only men with man bags get a pro maxThe max is just way to big, doesn’t comfortably fit in my hands and is way to big for most pockets. If you’re going to go that far you’d be as well get an iPad mini with cellular and carry that around.![]()
At 240g it's the heaviest iPhone ever. More than half a pound.
Return it for a different model.I'm kind of regretting getting the max but maybe I'll adjust over time. It's making my forearms tired and sore
Would love to but my nearest store is a 2 hour drive away - I may be up that direction closer to Christmas which is probably when I'd change anyway so might have to do that.12 Pro to 13 Pro Max, so almost the same. That was partly my reasoning for going for the Max this time - it made it actually feel like more of an upgrade. The weight is a subjective thing though really. Yes it’s quite heavy and was a bit of a surprise when I got it out the box but it’s not been a concern for me in normal usage. Your best bet is probably to try one out in an Apple store or something to see how you get on with it.
Indeed. Think it unlikely he'd approve to glass being used as a material for phones either. It just makes zero sense.
I’ve had all the largest Apple phones and I genuinely wonder what people are wearing when they say the phone is too big for their pockets. I wear everything from shorts to suits and I’ve never had a trouser pocket that was too small to hold a phone. Even when I was skinny and wearing 30/30 jeans, I had no problem getting the phone in the pocket.
What are you all wearing with pockets too small?
I do something completely opposite, never charge overnight, just 30min here and there. Iphone 11pro after 2 years, battery health 100%Interesting to know but I’m generally more concerned with prolonging the life of my battery than shaving a bit of time off charging. Usually just charge overnight anyway so doesn’t really matter how long it takes.
