Maybe the vRAM will be an issue, but there are updates to come for this yet I would have thought. Even if after updates and everything it is absolutely shown to be the vRAM which is the limitation, and that is the worst that happens, it's not exactly a disaster rendering the game unplayable.
I'm of the belief that 10GB will be enough, but not so much that I'm going to sit on a hill and hold a position forever - If it's proven not to be "enough" but that video is what happens? Fine.
I would ask why in the settings screen at the bottom, it suggests that it will need only 6.82gb of vRAM though, unless I'm missing something obvious. If it thinks it will need 7GB, and in actuality try to use over 10GB, it does seem that there are significant improvements to be made down the line.
Exactly, if the game does indeed need/require that vram, then great, it's settled, we finally have one game where having more vram is "required" (anything else that has been brought up has been 100% disproved with various solid pieces of evidence) but that's the problem with FC 6, we still don't know for sure what the issues are and people still have yet to provide a good answer to these questions:
- why didn't techpowerup, toms hardware, guru3d etc. etc. not see the same problems? If it was absolutely down to vram and nothing else, surely all sites should be reporting the same?
- why did jokers 3080ti drop to 5 fps (similar to what PCGH have reported for the 3080) in his game and all of a sudden taking a screenshot brought fps back up, seems a bit odd, no?
- iirc the game is also not launching/crashing on gpus with<6gb vram, funny how this seems to also be a first
- this is a first for where a game "runs" out of vram and fps drops entirely, do you really think that is normal or more a sign of something hasn't been optimised/implemented correctly? Bearing in mind, ubi have said they are working on it.....
- why does some footage with higher vram cards look like textures aren't rendering/loading properly too?
I didn't but I was swapping between FSR on/off. I did quickly start a new game and while legging it through the intro I did find a spot where the FPS tanked with per app VRAM showing at 9431MB!. At the ladders that take you back out of the sewers if anyone wants to check the spot out![]()
So the exact same spot as joker had that problem, should try taking a screenshot to see if that fixes it.
