- 14 Oct 2007
- newcastle
I decided to switch out my clear tubing to black, just deciding on purple or yellow now
A few bits to tidy up and waiting on delivery of my Mo-RA3 from ocuk in a few weeks
Thanks mate!Really cool! I like it
cool build- would the AE fit if you cut a hole in the PSU shroud as that would look so good thereDownsized my case and got new fittings/tubing to go for a different colour scheme, well please with the result!
Just need to find an enclosure to fit the Aquaero to.
A few bits to tidy up and waiting on delivery of my Mo-RA3 from ocuk in a few weeks![]()
Great stuff and yeah external rads help a ton with this case.Wowzers, that is really awesome, very nice work.
Think few pages back when I posted mine you said you will do a build in it one day, seems you really meant itGreat stuff and yeah external rads help a ton with this case.
. Fell in love with it as soon as i saw yours and thought damn that is one sick build! I swore on it and i meant it haha and here we are now. I'll admit its been quite expensive making this move but worth every penny, can't get enough of it.cool build- would the AE fit if you cut a hole in the PSU shroud as that would look so good there
First ever attempt at water cooling, up until now every PC I've had has been air cooled. Skipped AIO and went straight to custom loop. It's been a long time coming because I've had problems with my back, but finally got it together this evening:
Need to get the RGB LEDs inserted into the CPU waterblock and connected up, fancy a small RGB strip down the left inside of the case to give some extra lighting. When I come to get my GPU waterblocked, then I'll change the tubing layout. I was kinda hoping that the vertical bit of soft tubing might stay straighter, but it doesn't want to!
Quite pleased for my first ever attempt, please be gentle
Edit on 21/10/20:
And this is what the system looks like now, after I waterblocked the GPU several weeks ago. Cabling since tidied up and paper towels removed
I bought it from the EKWB online store, but as far as I am aware it's been unavailable for sometime now. I have promised the 1080Ti to a friend as I've upgraded to a RTX3080, so at some point the waterblock and backplate will go on MM.Ooooo! Where did you get the EK waterblock for the EVGA 1080Ti FTW3? I cannot find it anywhere.
This is sweet, excellent jobA few bits to tidy up and waiting on delivery of my Mo-RA3 from ocuk in a few weeks
I would call this "ghetto fabulous" over the term "ugly"
