- 24 Jul 2009
i had my 1 g fibre installed today!
its PANTS, 126 to 300 mbps.
been talking to them all day, actually one guy frome lila told me its better than my old ips!!!!! huh! my old isp was 35mbps lila should be in the 900 sssss
dam shocking, got an engin.... coming morrow, if they dont fix it they can dig it up.
warning to all.
Just done speed test on mine and I get 900Mbps down and 727Mbps upload. There will be an issue with the line, nothing wrong with their service.
Have you tried the speed test the engineers use: http://speed-uk1.vx.se/index.html
Also, what router are you using?
Are you testing on WiFi or ethernet?
Are you using at least at Cat5e cable for ethernet?
