Does anybody know if the £600 instal is still applicable, or is it just the 18 month contract and that’s it?
Thank you for your help, I think it’s a no brainer, the only thing worrying me is the static IP as I play a lot of games. No doubt I’ll have to pop them a quick call and see if they can offer me the static IP.
Assuming the dynamic is carrier grade natted then? Is the 4.99 per month or one off?I jus rang em.
Connection is dynamic, you can change to static at any time £4.99
Dynamic is carrier grade nat. Not sure on the price of static though, likely per month.
Am I correct in thinking that a static IP is only really needed for P2P type games?
Also just noticed that Lila only install ground level, that's no good for me since my router, pc and consoles are in the back bedroom.
First question: You can play without but likely to have a bad time. Main issue is that you can connect to others, but they cannot connect to you.
Second question: They install two boxes at your property. The first box is where the fibre will terminate into from the road. The second is the ONT box that you would plug an ethernet cable into that then goes to your router. They will install the ONT box to the front of the property by default, however you may be able to get them to install elsewhere. It would need to be reasonable though. I had the ONT box installed in my garage as it shares the wall with the living room. This was last December and they didn't charge me an extra for doing so.
I am looking forward to my install on Thursday. I was signed up with rocket broadband but heard nothing from them after months of waiting. I phoned lilaconnect and they said I can go directly with them £29.99 a month for 18 months. Walking around a large part of my estate there is no sign of anyone taking up this very good offer?.Virgin said they could offer the same speed for £62. I am wondering what the cost will be after 18 months.
