Caporegime
- 18 Oct 2002
Cracking one too, prob still the best performing.
Stop trolling, £200 for a £360 AIO.
https://www.overclockers.co.uk/arct...ormance-cpu-water-cooler-360mm-hs-07d-ar.html
£95
Just a heads up, I got the Arctic Freezer and ordered the LGA 1700 from them as well and it turns out I also need to order a new cover for the PCB as there are issues with them and ASUS motherboards
I ended up getting this one instead.
▷ MSI MEG CORELIQUID S360 ARGB Performance Liqu… | OcUK (overclockers.co.uk)
Mind if I ask your current outlay on the new tech. CPU, mobo, cooler ram etc anything else you've had to buy to get it all to work? You ok to list what you've got so far. Would like to have a look at cost to see if it's worth it for me
This is a solid board..... Add asetek aio your set....Dumb ass Asus, Z690 ROG STRIX Z690-A GAMING was my choice but it's not compatible with nearly all coolers due to VRM heatsink height.
Ddr5 runs cooler. Just aesthetics....Yep, not many air coolers gonna fit on that surely.
Makes me wonder why the M2 heatsinks on z690 are massive and why RAM needs active cooling.
Does this men pcie5 SSD's are expected to run even hotter than gen 4 and same for DDR5?
The only saving grace for this particular board that 99% of people who buy the Gigabyte Extreme would not even consider air cooling, most would be water cooling.
It's more than I wanted to spend:
12900k - £599
Asus ROG Hero - £520
AIO - £250
RAM - Can't find expect £250-300
Case - £120
Those are the big items
This new socket from intel is really causing some problems with coolers not much planning going on here.
AFAIK, these distances around the socket aren't standardised. I feel it's a little unfair to blame motherboard manufacturers when these ridiculous air coolers are taking up all the space!This new socket from intel is really causing some problems with coolers not much planning going on here.
