Yeah its the 48" version. The joy of having it wall mounted is that I can just moved the desk further away from the wall if I feel its too close.Is that setup in your garage? I can't unsee the car doors over there lol
I assume it's the 48" version? Damn, that tv size looks perfect in balance. OLED looks the best when the lights in the room are dimmed a bit to enjoy the vividness and contrast.
Still loving mine. Toggler toggle bolts are fantastic on plasterboard walls. Just working on a few bits at the minute, getting ready to wall mount some speakers and whatnot
So just got this installed today. What settings should I be using to enjoy it in all its 4k lovliness. HDMI 2.1 cable and a Sapphire 6800XT powering it!
Now you got a man caveIs that a Xigmatek Elysium pc case I haven't seen them from 2011
Good setup, won't the airflow be decrease on carpet for P.S.U and dust
my mistakeThey are quite thin carpet tiles. Never had a problem before.
I know the feeling mine is like a small fish tank and heavy want to place on the floor but I have carpet in my man cave just worried it might get more dust then it is now.Sure is absolute beast of a case, can't think of a reason to replace it!!![]()
my mistakeif it not problem fine just wanted to know
so did you get the speakers up
It's a beautiful monitor that can be used as a TV or a beautiful TV that can be as an excellent monitor much better than any other for playing games.So... Is this a monitor or a TV?
It's a monitor you can use from your sofaSo... Is this a monitor or a TV?
So Im using TransparentTB but I can still see the top of the search box and the in use app (firefox for example).
Its only a few pixels but its so annoying, is there any way to FULLY hide the task bar? EDIT: Nevermind, figured it out. Setting the search bar to an icon did the job. Now just need to find a way to stop active windows/apps doing the same.
people who use this as a daily monitor not scared of scree burn?
