Who says, some random on reddit? provide links proof. It's probably noobs messing up the install.
So I re did it all using 1.5mm gelid extreme on die side on VRAM and VRM and so far it looks promising just ran benchmark for around 10mins at stock and max temp gpu got to was 75c and hotspot at 85c so 10c delta which seems excellent Vram got to 84c this is in room with temp of 25c will have to test more I also used the paste syy 157 which is meant to be better as its thicker and not prone to pump out effect it was difficult to spread but found techniqueHahaha, go look for links proof yourself. We are not your slaves![]()
You have had your 3080 before September? is so that kind of rules out a recent cooler change. I have re-pad two 3080s, both run great. Anyone that wants their 3080 FE mem pads replaced, you know where I am.
So I've put that block on. I'm very interested in knowing what size pads you've used incase I need to replace. I have the 2mm extreme to hand as I was going to use them with the old cooler originally before doing the watercooling.I’ve had memory pads dry up after about 1 month of mining (they were stock thermal pads that come with Corsair water block for 3080). Replaced those with Gelid Extreme and they were rock solid constantly mining for about 8 months now keeping memory temp between 60-70c.
Definitely worth the price.
Tho ones I used were 1mm.So I've put that block on. I'm very interested in knowing what size pads you've used incase I need to replace. I have the 2mm extreme to hand as I was going to use them with the old cooler originally before doing the watercooling.
Cheers mate. I might return these 2mm then and get some 1mm extreme.Tho ones I used were 1mm.
@RavenXXX2 I got a 3080FE 2 weeks ago in the UK brand new from a copmpetitor of OCUK. Did you only do add gelid pads on the front side? i..e the side acecsible first without having to unscrew the X plate?You have had your 3080 before September? is so that kind of rules out a recent cooler change. I have re-pad two 3080s, both run great. Anyone that wants their 3080 FE mem pads replaced, you know where I am.
Hwinfo.What are you guys using to monitor GPU temperature.
This is the first Nvidia card I've had for years.
I didn't install geforce experience.
Thanks.
Where abouts are you based? If you in London I could order some pads and experiment. Also when you opened up your card, do you know what the MFR DATE was? My thermals at stock seem better than most other stock 3080FEs. Ive only seen it hit 100 degrees plus once in a whole week of mining. Warzone seems fine.
this card where I had issues with using 2mm gelid extreme is now running really good with 1.5mm gelid ultimate and Sy 157 Thermal Paste at stock seeing higher boost frequency I didnt get before even on idle I remember it idling at 31c with the fans off now its 25c same case fan profile at 800rpm which the card is getting airflow from and room temp is the same at 25c will run some more benchmarks tomorrow but so far really pleased
Room temp for both was 25c and running card at stock
this is with stock pads/paste
I remember the vram was around 94c
This is with 1.5mm Gelid Ultimate pads with SY 157 thermal paste it mostly stayed around 71-72c with odd peaks to 73c. Vram stayed 82-84c
lower temps while the fans spin lower , will be fun playing with undervolting seeing how the results are looking at stock
Good to see the 1.5mm Ultimate's are working well for you, as i mentioned above I've never tried the 2.0mm extreme pads and just went straight to the ultimate as they are the better pad of the 2 anyway and temps came crashing down and now no need to have the fans spinning so high constantly to keep it cool. Even at stock fan curve it will just sit at 60 core 94 memory while mining with fans at 39% so pretty much silent , Silence is golden![]()
who needs AIB at them silly prices
, still dont know why 2mm extreme didnt work on this recent one but worked on card that I got around 9 months ago, either nvidia changed something or gelid changed the extreme pads to be not as soft ?So just want you to spell out to me here bro.I have replaced thermal pads on 2 3080fe's also you have to take off the X clamp to get access to the vram chips and VRM on gpu die side this is the side that makes the big difference , backplate hardly makes any difference might as well keep that as stock
First 3080fe I did like 9 -10 months I didn't note down the date on the heatsink and I used 2mm gelid extreme pads and worked great made like -20 difference in vram and no issues with gpu core or hotspot temps I even redid with using another paste called sy157 as it's thicker so it's better to avoid the pump out effect and the heatsink contacting the die isn't totally flat , I also did the backplate with 3mm extreme gelid i wouldn't recommend doing the backplate hardly makes any difference and wouldn't use extreme pads for the back as they end up going all mushy and if in future need to take out all be a lot of cleaning to do
So my friend got 3080fe on the last drop heatsink dated 2021 I don't know if it was just me I was testing with stock pads so can note down the temps , scores etc so can compare after when switched over but it did seem it was giving better temps then mine was when at stock state vram temp was having trouble going over 95c whilst I remember mine going higher but it could just be the weather is cooler now
So I did exactly the same installed 2mm gelid extreme pads , left the backplate at stock . Vram temps great but really high gpu and hotspot few seconds into benchmark right to 100c so meaning the heatsink wasn't contacting the gpu die properly like the pads are too thick? So when taking apart again I did notice the pads on vram didn't seem as compressed as I did on my own one I could see clearly the shape of the vram print on my own one but not on the recent one
I even re did it using another pack of 2mm gelid extreme no difference
I did see few recent comments of people having same issue when following the old guide that worked with 2mm extreme I just thought those lot were just doing it wrong till I tried myself
So some suggested trying 1.5mm pads , so I tried 1.5mm gelid ultimate pads and it's solved the issue as you can see I posted screen shot I also tested mining vram didn't go past 84c fans at 60% giving 101 hash rate
So something has changed either gelid have made the extreme pads less compressible ? Or heatsink contact depth has changed ? I know it wouldn't effect the stock pads Nvidia uses as they are really soft pretty much offer no resistance
I have a 3080FE in the Nov 2021 drop in UK.
What Gelid pads should i buy in your opinion?
Just by looking at stock temps i feel they are better than launch 3080FE thermals. I am mining right now on it and am seeing mem junction temp of 96.2 degrees and I am really pushing the OC to get 96MH/s. Would be lovely to reduce it by 10-20 degrees though
Am i to buy GELID Ultimate 1.5mm for the VRAM (back) side and just leave the front side with the stock pads as it is not really going to have a big impact.
I really appreciate your input. Such valuable info you have posted, as the lines have become blurred lately with the new 3080FEs.
