You can get New Super Mario brothers U deluxe from amazon at the moment for £24.99 if you pick it up from a pickup point using code 5TRYPICKUP.
i tried, but The promotional code you entered cannot be applied to your purchase.
I have just borrowed a switch to play Luigi's mansion...I don't want to break anything or overwrite anything - I assume I can create a profile plus additional save games so I don't break his stuff?
My switch oled comes tomorrow, so can I use a cable to transfer everything over ?
Or an SD Card if you have one.
No, local WiFi.
i do have a 64gb one is there a set process? Or is it a case of copy data over?
All of my games I have brought on the shop, is it a case of just logging in using my Nintendo account and then download ?
Also does the OG official case fit the OLED Switch at all ? If not ill be getting another case shortly.
Cheers y'all
1. Yes but make your new Switch the primary Switch or you will have to always be online to play your games.
2. Yes.
For the N64 classics via the online membership, are they downloaded and run locally or streamed via cloud *****?
As above but you will need to be online to verify you can access them.
