Do people tend to run water proof boards down to floor then have the shower tray installed up to these with tiles on top?
Yes.
Do people tend to put backer boards underneath the shower tray e.g. Hardie backer?
No.
Is fixing the shower tray down with tile adhesive best bet? Could use the same adhesive I dot and dab boards with?
Yes and yes.
Whats the best adhesive to dab the jackoboards to wall with?
Any cement based powder adhesive (not plasterboard adhesive) I use ultra tile fix for most of my tiling as they are well priced good products. https://www.protilertools.co.uk/pro...x-sp-rapid-set-flexible-s1-adhesive-grey-20kg
Prime the walls and floor before dabbing/trowling. https://www.protilertools.co.uk/product/ultra-tile-fix-proprimer-advanced-polymer-primer
Use a class S2 adhesive to tile the floor, the previously linked adhesive is fine for the hardibackers though. https://www.protilertools.co.uk/pro...bre-reinforced-flexible-s2-adhesive-grey-20kg
I would use a classi seal on the shower tray, this adheres to the tray and crates a tileable lip which should ensure no water can leak, it is better than relying on silicone. I've got some pics of one I did.
1st, Boards down to the floor, all board edges fitted together with multibond, you can use silicone or CT1.
2nd. Boards taped and you can see the classiseal (blue strip) on the shower tray
Floor was overlayed with hardibacker shower tray before tiling.
Will you be tiling yourself?
