Does it really matter which DP port I use, chances are I'll be faffing for a while yet, missus is off out shortly, my DP extension right angle has just turned up and so has my standoff kit, shes going to Ikea so I should get about 3 hours to play..
Case has now been purchased!
I have a NVME on the back of the motherboard (Western Digital Black SN750 2TB - no heatsink). Do the default standoffs that come with the case provide enough clearance for a NVME to be present and only heat is the concern? Or will additional standoffs be required regardless?
I have a NZXT Kraken x52 240, does anybody by any chance know what the max standoff size allowed for this AIO?
And in terms of standoffs is it the M3 that is required? Any brand fine? best getting brass? or are the black nylons durable enough to hold the weight?
Thanks in advance
The right angle of the Display Port cable does matter! I ended up getting the wrong one!
Yeah, I'm aware of this "legendary" piece of software having tried to use it on a Gigabyte motherboard to get the RGB working on my Crucial RGB ram as that was unbelievably a suggested solution. Needles to say it didn't work and installed a load of crap! So I've not installed it this time around and use OpenRGB to control the RGB. It does detect the Asus motherboard RGB header and does allow my to control the colour of the EK CPU block and given the GPU block is off the same header via a splitter, I'm not sure why that's not working.Armoury crate, you're going to be introduced to the downside to Asus Mobos. It's a piece of software that has the Asus Aura Sync rgb controls in there. It is also buggy and doesn't play well with others.. see Corsair RGB ram.
open up Armoury crate, select Aura Sync and select and sync all devices you have connected /it detects and go from there
Good shout actually. I did set the number of LEDs to the amount on the CPU block, not the totalDoes the EK Splitter just replicate the DRGB signal, or does it effectively daisy-chain them? If the latter, did you set the number of LEDs in the chain in OpenRGB to the sum of the number of LEDs in the two blocks?
Now I need to change it but I can't recall where I found the setting!Good shout actually. I did set the number of LEDs to the amount on the CPU block, not the totalNow I need to change it but I can't recall where I found the setting!
On the devices tab, select the appropriate motherboard header under the zone drop down and click resize.
