No manual? Is that a thing now...
Ideally, for 4 DIMM kits, they should be matched and on the QVL, I do recall running 4 DIMM DDR5 means you need to run them slower.
However, ensure you are running the 0811 bios as that helps with memory a lot, but it could be the case of needing to manually tweak the settings.
So annoying.
If it was a £50 board it still wouldn't be acceptable.
Main m.2 slot (top most one)?
Nice result there, down binning on or off? That must be a pretty good CPU is its fixed.
6200 Profile is all sorted.
Very nice got mine to 6000, just wondering what voltage you using and mem temps?
zia
Good to hear. I was lucky that I managed to bag a 2070super before the prices went too silly (I could actually sell it today and make a profit!)I play at 1080p with a 12700k and a 980ti 1490core/1950mem and it is pretty damn fine
This current system has done very well for the last 7 years.
Nice! Can I ask what voltage was required for that?5.3 all core on my 12600k. I’m maxed out on core will work on cache and ecores next.
Just a nzxt x63 aio in a meshify c. Asus prime p bottom of the line up board.
