- 24 Mar 2018
- Brighton
the pihole just resolves on port 53 dns queries but your need to change those on the router
what is the ip of your dns servers ?
so my pihole servers are 192.168.0.8 and 192.168.0.10 so thats what I would set my dns to in the router
In any case you would turn off dhcp on your router if you was using the pihole as dhcp
strike that.
but those routers are very limited, and I am not familiar with that Hub setup
It depends how that router is setup, if your disable DHCP for the Lan then the router might also be disable local dns forwarding. I don't see why you would want to forward dns from the router when pihole is handling the DHCP and DNS. Also some devices/routers do forced DNS direction.
strike that.
Yes. It works fine with a public DNS (eg google 8.8.8.8). It doesn't with the Pihole IP.
Awful app, and now hate it even more with the hassle its giving me!
Good suggestion, right now as a temporary fix i have put her phone onto an external DNS. Ironically though i now get complaints that the adverts are everywhere (which they are, its near unusable, full screen videos which you cannot cancel until after a count down etc - who puts up with this ****?)
