Have you test fitted the bath + shower tray. That looks mighty close in the diagram, to the point where the thickness of adding tiles might make it too tight.
Shower trays and baths are fitted before tiling.
Aye i was going to fit my waterproof boards before both though as I think you and I previously discussed.Shower trays and baths are fitted before tiling.
No, I don't believe it's necessary for the regulatory requirements. I also will know not to drill there. It'll be filled with sound insulationAre you putting that wiring into a conduit?
What do you mean the niche will be in front of the plasterboard? First photo looks flush. I'd have thought the thickness would be if you were relying on the plasterboard for support. Being attached to the frame would make that irrelevant.
I meant that the niche would need to be proud of the plasterboard so that the tiled surface was all level once he'd boarded it with a waterproof wall. But I really don't know if that's how it's done with these pre-fab niches, vs. keeping the niche flush with the plasterboard then putting marmox / other over the niche so that the tiled surface is flat.
Tile adhesive is not waterproof. I already said silicone or multibond between boards and then waterproof tape. (Mesh tape is only for non wet areas)
Why did you put the niche so close to the wall as well, a tiny slither of tile up there is going to look bad.
Is 'Waterproof' wall tile adhesive not waterproof? I guess it's just more water resistant.Tile adhesive is not waterproof.
The niche is in a nice position I think the comment is about whether you've allowed yourself any at all for the tile. You could end up with a tiny slither of tile versus an inch or two (i.e. not much more, but enough to make it not stand out).Aye ill go over them with multi bond and waterproof tape.
The niche is in my preferred position, I considered centering it with the tray but would rather have it tucked in. I saw a couple examples on pinterest against the wall and looked OK after someone else pointed it out.
I use a waterproof grout then a grout sealer to make sure none gets through.
I would agree, as a solution though he could sacrifice some niche width and put some board on the left vertical to make more room for tile. Not ideal but...The niche is in a nice position I think the comment is about whether you've allowed yourself any at all for the tile. You could end up with a tiny slither of tile versus an inch or two (i.e. not much more, but enough to make it not stand out).
