Yes I know, I'm just wondering when the penny will drop with the population that some of this at least is avoidable.
No, Netflix charges for the screens as well in the 4k package making it extra expensive as well. They could offer a cheaper 4k sub with less screens, that's what I'm trying to say.
Disney plus has a set price that includes 4k. Why has netflix got to have all these different subs.
One 4k stream would still be 2x the bandwidth of the lower 2 stream 1080p sub though at £12pm, so wouldn't be much lower in price, and Netflix use the average bandwidth per subscriber, I can imagine that one household with 2 screens would actually use less than half the bandwidth of one 4k screen because each person in the house probably wouldn't be watching for the same amount of time.
I have a commute of 80 miles per day, time to look for another job!
Thanks, what did you replace it with?Had one on our front door before replacing it, better than nothing and inexpensive.
A new door?
I've no doubt their supporter base will be mugged into blaming someone else... Those ****wits will probably be shortly telling us it's Meghan Markle's fault.
Back in the real world, here's an interesting thread...
You could say.....I walked right into that oneYes a composite door, problem solved.![]()
.As well as the draught excluder at the bottom of the door, I fit brush sealing strips all round the edge, it definitely made a difference. Also, check your letterbox, that's another area that can be quite draughty.You could say.....I walked right into that one.
We're renting so looking for simply/easy solutions now. Need to get a timer set up for our heating since we got a new boiler, habit is definitely another area to look at and easy fixes like draft door stoppers.
Thank you both. Forgive my ignorance - how difficult a job is doing the seals/can you DIY? Same for brush sealing strips? My DIY knowledge is pretty low but always willing to learn, within reason.The best thing I had ever done regarding that was replacing the rubber seals around the inserts of the front and back doors. Never needed draft stoppers for that purpose. Even fixed up the letterbox to stop any drafts. As it was originally metal to plastic for the letterbox.
Draft stoppers were always things I remember at my Gran's because the seals were worn after decades.
But this is wrong, the figure for brought energy for UK energy firms has multiplied by almost 5x so that figure of £389 should be £1945.
Using the Gas price March 14 2021 = £44.05
Price now for Gas = £285.0
That means the price for Gas is 6.47x what it was this time last year.
Also to note over 10yr the price has been between £35 and £65. Apart from Covid 2020 influence when everything went into lockdown it been pretty consistent till now. Big spikes in the last 25yr were 2005 and 2008 but were short time frame.
Electric in price March 2021 = £57.04
Electric price now = £243.96
That means the price for Electric is 4.27x
So yeah, based on that figures given and what SSE costs are (ignoring that inflation is even a thing with this persons figures apparently doesn't exist) then the new total would be closes to £2839 which is suspiciously close to the £3k figure mentioned. Like seems to have completely ignored that SSE are not the ones setting the wholesale price they pay and thus are not the ones profiting from this.
Keep in mind that not all forms of electricity production have seen massive increases in costs.
Companies that can produce electricity at a low marginal cost and then sell it for 30p per kWh are gonna announce massive profits. Same goes for any oil/gas producers which do exist in this country.
If Centrica's profits don't increase massively, they are doing something wrong. It's inconvenient that they are doing this by charging British Gas much higher wholesale prices. EDF also produce their own electricity. Don't know about SSE.
