Now finally installed and wall mounted. Looks amazing at 120Hz RGB 12 bit.
10 bit panel.
You have any pink tinge on full white or grey screen? Can you post a pic of white screen, straight on.
10 bit, ok.10 bit panel.
Looks awesomeNow finally installed and wall mounted. Looks amazing at 120Hz RGB 12 bit.
I guess its up to LG to now propose what the state of play is, as you may get a proportion of people buying the panel who are not enthusiast or looking to use it as a gaming monitor however if people are sharing how to spot issues and its deemed misleading advertising I wonder what the vendors are doing? Unless this is quite common with displays/TV's.
Yep fingers crossed this one will be better or I will be devastated lol. Really don’t want to go trough exchange again and RS probably wouldn’t be very happy either as so far they’ve been very nice to me.
Fingers crossed, at least its not like the 48" panel where you feel like the panel could crack when you go to pick it up or move it out the box
This 42" felt almost half the weight when I went to lift it up.
Yea this one weighs next to nothing. When I was removing the screen protector both pull tabs came off without pulling the film so I had to get under the protective screen with my finger nail very gently.
As I was doing that the corner of the display was slightly flexing within the frame as if it was made out of plastic and not glass. Weird.
The 55” BX that I got in my bedroom I was hanging that up myself as was too impatient to wait for help.
I had to use steps to hang that up on a wall so it was a bit of struggle as it weighs way more than this 42”.
@R3X don’t know if you can disable the red standby led but you can change it to white if you enable “always ready” where you can even power it on with your voice as it’s always listening.
For this new gen they have also moved to using composite materials, so in addition to the size bit, they do weigh less in general, 30% or so on some models year on year. 77C2 this year dropped down to 21kg vs 27kg for last year. Including stands, difference is even bigger.
Has there been any updates on an easy way to tell between the old WBC and the new WBE panels in the 42" C2?
Also I've noticed people talking about the 42" not having 120hz bfi... is this a big deal? I didn't realise this was necessary on OLEDs, and I will be only ever using this tv at 120hz.
Menus appear more simpler and easier but pretty much the same, can't see the option to switch off the red front LED light though but will keep looking.
.Early thoughts on the 42C2 are, its the best picture quality I have seen on any TV, very pin sharp and detailed. Straight away I noticed few difference though compared to my OLED CX from 2020, LG put the hdmi ports now on the left hand side rather then right hand side like on the CX, this is a pitta since my daily 4K monitor and wall is on the left, its not going to be easy to swap cables but guess you only do it rarely.
Also all 4 hdmi and other ports are on the left, so no nasty hdmi or optical ports on the back like the 48cx, what a fiddly nightmare that was. I do miss the universal entry on the optical port on the CX though, the C2 optical input has to be put in the correct way, again nothing really to fuss over. The 42C2 has better reflective coating then my 48CX, Can barely see myself or lights on the 42C2 on the 48CX it was practically a disgusting mirror of myself. Menus appear more simpler and easier but pretty much the same, can't see the option to switch off the red front LED light though but will keep looking. I did do the Full white screen Youtube test with Filmmaker mode and I don't know what I have, if I look at an angle on the left its a very slight pink on the right hand side of the screen but if I go on the right hand side and see it at an angle its a blue tint. So I have a blue tint on one side and a pink tint on the other side perhaps LG made sure I got an Semi-Evo panel![]()
Every oled has the same gloss to them and they have good anti reflective coating. But C1 & G1 models had a pink tint bug last year so it seems they didn't fix it for C2
Red tint have been found here https://forums.overclockers.co.uk/threads/lg-42-inch-oled.18945242/page-37#post-35529569I hope this one would last you more than year!Every oled has the same gloss to them and they have good anti reflective coating. But C1 & G1 models had a pink tint bug last year so it seems they didn't fix it for C2
