- 9 Dec 2009
- Bristol
Replaced the led light in the cooker hood. It has started flickering and died. I found an led bulb in my box of bulbs which had the same small screw fitting.
Username checks out, presume you used a credit cardBought a car online whilst drinking last night. Doesn't get more man than that (except if it was on ebay, which it wasn't I'm not that alpha).
Username checks out, presume you used a credit card![]()
They have a text number so I sent them a text, they replied and got me onto WhatsApp so you don't have to wait around all day for a reply. They first came back with £138.70 .... a £1 discount. So I said no, I said I'd pay £89 or leave and they said OK
I priced up sky but with BT sports it was more expensive per month with no unlimited sim and crappy fibre.
Buy some pipe insulation next.Finally bought some racking and sorted the garage out.
Nope but they do lose heat.Does it seriously get cold enough to freeze pipes in a garage?
Looks good, never really thought about how much more work and angled garden is.Had a weekend project planned to build a raised bed. Boshed it off today
Before
Laid out the boards
Was tricky due to the slope of the garden but measured twice (at least) and dug out for the deepest side
Mocked up the posts and facing board
Got squared up and post creted them in
Aligned the sides and back for more hole digging
Then started to fill the sides in
Got the sides in and lined the inner walls with visqueen
Then topped off with a coping / cill to finish the top off and hide the posts
"Done"
Got several tonnes of topsoil coming Monday to fill it up
Good point, hadn't thought of that.Nope but they do lose heat.
Wow, I felt bad digging out a few inches to level the kids playing slide thing.Thanks, I'm really pleased with it. Yeah it's a bit of a pain, that's the most sloped part and was a bit of a waste and ideal spot due to the sun it gets. To give you an idea of the slope it's 600mm high at the tall end and 100mm at the short end just 2.4m away
Unless maybe it's the waste, and it drips more when being run though? I spent ages trying to stop a drip behind my bathroom sink. I'd think it was sorted, but then a week later after draining a full sink realise it had soaked the boards again.Wow, I felt bad digging out a few inches to level the kids playing slide thing.
My job tomorrow is to investigate a leaky tap, it's leaking from under the sink, but not sure from where. Only noticed as the kids wanted to do some painting (stuff is stored under there) and the tub had half an inch of water in it. Considering that the drip is only every few minutes, it must have been going for a long time.
