They never gave me any issues. Got my promised 7% refunded.
I would chase them up if you can be asked, they will give in eventually I recon. Weird how inconsistent they are though.
With Quidco first you need to make sure it shows in your account as tracked which should be within 24hours, after that you just wait for a month or two until they either pay or reject it. Been doing cashback for years, easily got back a four figure sum using Quidco
/TopCashBack over the years![]()
Ah yeah just looking at the control panel on quidco now, bit of a wait that!
Ok, so, phoned Dell customer support, after a bit of to and fro, I was offered a 7% discount on my next order. I politely declined. Asked to speak to the manager, then put on hold and they agreed the 5% so brings the initial cost to £804.65, still waiting on the AMEX cashback. Hopefully should bring the total to £704.65.
Thank you for the motivational push guys.
I will now be nicknamed a 'Karen' on the Dell Customer Support side.
Nice. £14 cheaper than me, but I got tracked cashback which is over fifty quid as I recall. Also got another one on the way which I will sell on so will work out £400ish in the end![]()
Dirty scalper.....
