Im not sure if i should have got my 5900x last week instead of the new 5800x 3d but as always there is always something better around the corner
Which ever way you look at it. It's a cracking CPU for gaming and AM4. And for those moaning about it not being great for productivity, it's hardly bad is it. You need to be doing some serious work for it to be a hinderence. Something I doubt most who are crapping on it actually do.
I could do but im happy with the 5900x coming from a 3800x so the extra cores might be of use in the future as i dont game enough these daysThe reviews have been out for quite a while, you may be able to return it but you're not missing out that much.
No point buying the 5800X3D unless you are a gamer who wants the best gaming CPU.I could do but im happy with the 5900x coming from a 3800x so the extra cores might be of use in the future as i dont game enough these days![]()
FixedNo point buying the 5800X3D unless you are a gamer who wants the best gaming CPU on the AM4 platform![]()
Let's see some UE5 benchmarks guys!
https://www.reddit.com/r/hardware/comments/u9sui7/one_reason_the_ue5_matrix_city_demo_is_so_cpu/
Got a download link for it and I'll run it to put up some results later?Let's see some UE5 benchmarks guys!
AMD GPUs don't perform very well in UE5 when paired with a CPU that has a small L3 cache; now I want to see what happens with a large L3 cache like the 5800x3d
Sounds like too much effort. I’d do it if it was an executable I could launch and then just run around for 10 minutes.You will need Unreal Engine 5, download the project in its raw un-built form (90GB) and then compile it in the engine.
Or at least this is how it actually goes: After an hour of compiling it will throw up and error and cancel, spend an hour googling what the problem is and fixing it, start again, an hour later it will throw up a new error and cancel, google again, fix it and start over... rinse and repeat -Unreal Engine.
I really can't be bothered with this right now, maybe later.
come the future those will just be a lot of slow cores. few generations down the line a quad core will surpass the 5900x.
Have downloaded this, will try and get it to build when its finished verifying.Once its complied it is a simple executable, like a game. someone could upload that but it will be a game size file.
