I would go for the Clio 182 out of those two. Megane 225 has marginally more power but no LSD unlike an R26.
The Clio is cheap for brake discs, pads and tyres if you go for 15". Then save more if you fancy something much faster.
Thats the thinking, though doesnt the F1 225 have a LSD?
Has anyone got any experience with Custom Production from Doncaster?
My Clio 200 (10 plate) died on the 22nd as I arrived at my brothers for Xmas, after a 200 mile drive, literally stopped 10 yards from his house. Sounds like the rods have gone...
So, man maths says....I can either replace the engine (and inevitably gearbox on one of these at some point), sell the car as is and buy something else or drop the Megane engine and R26 diffed gearbox in it and they'll all end up being the same cost(ish).
Custom Performance will do the work for about £4k with the box being an extra £750 on top of £3.25k on the basic engine package.
Engines are compression checked and inspected, new ancillary parts, downpipe to meet original exhaust and the loom modified to take the new engine.
Work will take 7-14 days and they will recover the car from near Derby, though I am now stuck 200 miles from Newcastle for now....
They're calling me on the 29th to discuss in more detail.
Pics pleaseWell I went for it....
I have now got around 250bhp/torques through an R26 diff. New cup dampers with HKS springs with a small drop. Replaced the steering rack which had play in it for a good 2nd hand one.
It's totally transformed the car, I never liked it really, but now it's a decently quick hatch and handles like a dream.
Have about 5 of these little stone chips now sadly on the front bonnet & 4 on the front windscreen that seems soft alsoLooking lovely. Just washed mine and am posting to celebrate its first stone chip, just shy of 1 year old.![]()
She's growing up so fast. Front of the bonnet! Can't be prevented. Seems these will show up on Yellow really badly
I got a quote of £1899 + VAT to apply Xpel PPF for the bonnet only or £899 + VAT for just the front edge where most of the impacts are
think I will pass on that & just live with it
it's only a weekend toy for me, plans are get it in for a cambelt change soon as possible, I'm going to do a full paint correction also, oil looks fairly new so will hold on for a while, I absoloutely love it and they're as every bit as fun to drive as I remember.
Back in a Renault Sport 197 after a 10 year hiatus from the series...
Previous cars, 172/200..
Picked this up for 2.2k... 109k + 11 months MOT, in my fav colour & purposely the cheapest in the country, no service historyit's only a weekend toy for me, plans are get it in for a cambelt change soon as possible, I'm going to do a full paint correction also, oil looks fairly new so will hold on for a while, I absoloutely love it and they're as every bit as fun to drive as I remember.
Had a recall on the RS 300 today!
A turbo charger hose pipe needs to be replaced following checks by their team.
Free obvs, just a pain![]()
I've heard that from others too, but I haven't received anything? Mines 2019 if that makes any difference.
Have a look at yours see if its leaking before driving any further is a good idea.Cheers, thanks for the info. Tbh I'll just book it in, best to be safeThink the recall is only certain cars (Trophy-R mainly) based on serial number. Its because some cars got a nasty split in the turbo oil hose which can & will cause a nasty engine fire as the oil can drip out in little amounts. The extreme heat in that area means it rapidly gets out of controlHave a look at yours see if its leaking before driving any further is a good idea.
1: Look on the far left hand side of the engine bay facing the car from the bonnet side.
2: Look towards the back near the windscreen you will see the turbo (its got some yellowish metal shielding around it). Well under there about 1.5 ft away is a small metal braided hose perhaps just under 1 ft long (you cannot miss its the only small one in this area).
This is the hose in question if it leaks you will see small drops underneath the top of the engine will be dirty. If its clean yours is fine for now. If its dirty do not drive the car anymore in case it catches fire! Someone's MK4 caught fire recently & got written off!
Not good might be the heat doing this though! Try the following (incase its just an ECU or sensor glitch). Cheaper than paying the dealer to hook up to their computer as they charge for this service!
1: With the car stationery & the engine bay cool disconnect the negative battery lead (be careful here or you get a nasty shock BTW).
2: Wait near the car for 30 mins approx as no alarm enabled so its fully unlocked.
3: Now carefully reconnect the negative battery lead & make sure you tighten it up properly.
4: Close the bonnet start the engine & the most important part is drive the car a few ft otherwise it will not reset the ECU if you do not start & move the car a bit in 1 direction to register the reset via the wheel sensors!
Now you have just reset the ECU so if the check light comes on & stays on then you have a genuine problem & or parts failure.
If the light stays off its just an ECU or sensor glitch & you cleared it without paying a Renault main dealer £95 +VAT or whatever they charge now to do this on their computer system which hooks up to the OBD port (under the onscreen display computer).
The ECU will now need to relearn your driving parameters & will initially feel way faster & smoother because of this!
They will not charge if its a warranty covered item that failed (5 years or 100K miles as long as the rear window warranty sticker is intact!). I think most likely its a sensor or heat related issue and clearing the ECU will fix it! They will charge to diagnose but if its under warranty I think they waive the charge so would not worry about it that's part of the cost of doing business so not something you need to pay for as they could see the dash warning message. What you might need to clear up with them is if you should drive the car as they might use it as an excuse to say you caused more damage driving with the injectors like that though....!! Right now your car is in limp mode that's why the dash is not fully available. Still think its just a caching software glitch like the one I had which said steering failure, brake failure please stop (all went away after the ECU reset & 10K miles later no issues apart from needing 4 new tyres & brakes being worn 40% due to so many miles in 6 months!Thanks for this reply I shall try it out in the morning and let you know how it goes!
I assume if there is a fault, it will be covered under the warranty? (I've not had a newish car before with such a warranty, so not really sure of its extents.)
It sucks that they charge to hook it up, but they did tell me that before when I first got the car and thought I had an issue.
They ended up not charging for some reason
