Factorio was a huge increase
-30 all core. Cinebench sits between 4.4-4.45 all core and doesn't go above 80c so I've got an extra 200Mhz and lower temps. Noice.Well I got it installed. Toasty AF in Cinebench (89c) so I guess I'll have to start messing with PBO2. Massive increase in performance over the 3900X before, especially in Flightsim. Good job AMD.
Impressive, I need to get this set up myself.-30 all core. Cinebench sits between 4.4-4.45 all core and doesn't go above 80c so I've got an extra 200Mhz and lower temps. Noice.
Cheers, much appreciated.Download the Debug-CLI.7Z file quoted in post 766 of the thread below. I just went with -30 as other people have had success with that and left it running for a couple of hours. Will test more but it seems fine.
CoreCycler - tool for testing Curve Optimizer settings
www.overclock.net
And here's a 3090 run overclocked.Managed to better my previous score in SOTTR 1080P Lowest Settings, also managed to just break 400 CPU limit.
Can't improve on the above without more memory frequency, FCLK and or BCLK. Unfortunately more that introduces instability to the system (WHEA and errors in TM5) which I have not been able to solve as of yet. This looks to be the max stable overclock for 24/7 gaming.
When you say a few times what do you mean? Can you suggest a stability test? Ideally something that does not take ridiculously long.Only a few mins. It's short but stressful.
My test suite is YC2.5 a few times and then occt large/avx2
I wonder when these will be available again
Good choice for Flight Sim 2020. I'm betting with the cache they will age a little better than some other chips for gaming. As GPUs are looking like they are getting a lot faster a step up to 4K later could even prolong the life further.I have ordered this CPU to replace my R7 1700x and will be using it on my original x370 Crosshair 6 motherboard both from 2017. I'm thinking this should make a bit of a difference in gaming like Flight sim 2020. I was considering a 5800x but as mostly use my Pc for gaming can see this as a better option. Impressive that I can do this upgrade and hopefully get several more years out of the board without replacing it all.
