AMD looks ever so "slightly" better (would agree with the splitting hairs comment, funny how people can notice that without zooms but yet the same people can't notice RT or dlss differences
But remember, it's free....
Hopefully see it get adopted more quickly and widely now given it worked wonders for dlss.FSR 2.0 plugin has now been added to Unreal Engine 4 and 5.
https://videocardz.com/newz/amd-fsr-2-0-plugin-for-unreal-engine-4-and-5-is-now-available
The name of the studio who ported GoW to PC is called JetPack Interactive.Per Alex: GOW came out of nowhere with fsr 2.0 update...They accidentally released the UI string for it at one point...(earlier then it should have).
But it's a little bit strange that it's actually listed. Because FSR 2.0 actually doesn't support DX11. Ah, which is curious. They said they [AMD] only work with developers on a per game bases. They wouldn't release DX11 code for FSR 2.0. So this is a custom job. Ah, by the team their at...I forget the team name of the studio. Rocket Studio...No, no it's the porting house. I don't something like squirrel...
Good find. I wonder why that important information was missing from the comparison? The mind boggles.
Supports:
- DirectX® 12.
- Vulkan®.
- Unreal Engine 4.26/4.27 and Unreal Engine 5 as a plugin from the Unreal Marketplace.
AMD FidelityFX™ Super Resolution 2 (FSR 2)
Learn even more about our new open-source temporal upscaling solution FSR 2, and get the source code and documentation!gpuopen.com
Tiny Tina’s Wonderlands becomes the next game to support FSR 2.0
Borderlands spinoff Tiny Tina's Wonderlands gets AMD FidelityFX Super Resolution 2.0 support - VideoCardz.com
Fourth game now supports AMD FSR 2.0 Tiny Tina’s Wonderlands is the first game to support FSR at launch. Tiny Tina’s Wonderlands is a picturesque first-person shooter developed by Gearbox Software. It is a spinoff of the very popular Borderlands franchise developed by the same company. This...videocardz.com
Lets back up a bit and see the forest instead of the bark of the tree.
God Of War uses DX11. No one disputes that. And, it's a perfectly capable API to use although a bit dated when compared to the flexibility of Vulkan and DX12. However, there is a bit of information that wasn't shared in the FSR 2.0 vs DLSS video comparison that I believe is very important. FSR 2.0 wasn't/is not compatible with DX11 API. And it came directly from Alex himself in a prior video/podcast they did about a week or so before the fsr 2.0 vs dlss comparison.
@52:28 to around 53:30
So, the question is if these issues are found using AMD's competitor's hardware it's apparent that Jetpack Interactive is at fault for their custom, jerry rigged version of FSR 2.0. It's certainly clear that they got no support from AMD.
Furthermore, it's said that most of those odd ghosting, smudging IQ issues are removed once the game is modded to remove DoF and TAA. For example, take a look at the images below:
Original
TAA/Sharpening/DOF OFF
Personally, with this bit of information we are looking at the issue created by the developer who ported the game. And, it's appears there is room for improvement. Lets hope they update their custom FSR 2.0 and see if things improve. I've tested it myself and didn't find most, if not all, the issues presented by DF. However, most of those issues they spotted were found with in 1-3 frames or less. Something, I don't see while playing. You have to slow down the game play to 10-15% normal speed to even see if they exist. IMO, even if DF found that issue with their 3090 it's a non issue at normal speeds because it's nearly impossible to see the majority of it while playing at normal speed. I certainly cannot find the information I quoted above in the FSR 2.0 vs DLSS review.
I wonder if he will tweet about this version of FSR 2.0 being a "custom job"? Since I never found that bit of info in the IQ review. To be fair this is a jerry-rigged version of FSR 2.0 used in DX11 without any DX11 code from AMD. I guess for a reason.![]()
Tiny Tina's Wonderlands: FSR 2.0 Review is up on Techpowerup
https://www.techpowerup.com/review/tiny-tina-s-wonderlands-fsr-2-0/
The review starts positive like mentioning that FSR 2.0 improves the quality of vegetation and grass in particular vs native image across all resolutions but image stability of thin objects has issues.
Performance uplift at 4K resolution is great but there is a noticeable texture quality reduction, and 1440p/1080p suffers from a weird performance hit that could be due to the developers implementing the FSR 2.0 render path itself incorrectly.
Unfortunately it's a pretty bad implementation and it's better to just leave the game on native
That's quite amazing that people have managed that in such a short time frame.While I'm unsure if CDPR will add in FSR2 to Cyberpunk, Would be nice if they did, A modder has put FSR2 into it thanks to AMD releasing the source code with very promising results that uses the existing DLSS options menu, Disable motion blur or you get weird black lines.
FidelityFx Super Resolution 2.2 - FPS boost mod
Boost your FPS in Cyberpunk by replacing DLSS with FSR 2.2 which works on all GPUs.www.nexusmods.com
So based on this I guess all games that support dlss can be modded to support FSR 2.0
Isnt that what Dicehunter linked on #432 @fs123 ?
Ah so FSR 2 doesn't support dx 11 officially then. Have amd got any plans to add "official" support for it? Although I wouldn't say it was entirely down to dx 11 as the ghosting issues also plague farming simulator, which is dx 12.
Sadly that is the way amd want their tech to be used i.e. once they have done their bit, they want to take a step back and let the industry do as they please hence why their previous technologies like tressfx, audio feature that was in thief (cant remember what it was called) etc. never got used widely.
On the TAA bit, that should be disabled as soon as FSR 2 or dlss is detected, at least that is how it works with dlss in games i.e. once enabled, AA option gets disabled and greyed out. DOF I find usually causes problems with upscaling tech too, was a similar issue in guardians of the galaxy where if DOF and dlss was on, you would get the weird artefacts. It's why I keep telling people you shouldn't be adding sharpening either as it will increase any artefacts in the base image.
Quite the accusation that...The most important question: Why didn't Alex at DF disclosed that AMD did not release DX11 code for FSR 2.0 in GoW? Making FSR 2.0 in GoW a jerry-rigged, "custom" implementation. If we are to view him as unbias? This comes off as some sort of agenda otherwise. As we know now the DF review is about how well Jetpack Interactive implemented without AMD's help. Although I cannot prove it I do believe that the developer disclosed those flaws to Alex.
The DF review of FSR 2.0 vs DLSS made it look like AMD was at fault when it was Jetpack Interactive who is the culprit for a poor implementation of it for a DX11 title.
It's clear that the game needs a slider/toggle to reduce/remove TAA and DoF. As well as a toggle to remove any additional sharpening and vignette used to compensate for enabling TAA/DoF. This should come from the developer. As we know copeious amounts of DoF and TAA is used as a cheat to hide any odd artifacts they couldn't resolve in code.
I forgot the correct technical terms but apparently DLSS2 and FSR2 share the same ground work so any DLSS2 game can have FSR2 added to it pretty quickly.
Yep it is but it's no biggie![]()
Please note that the modder specifies he does not have enough access to engine variables to make it look nice. He says this is a ghetto hack at best and a proof of concept, not something you should use for anything other than "cuz it's interesting."
