- 4 Nov 2004
I have an Aorus b500i + Ryzen 5900X. I have the latest stable BIOS installed and completely reset the CMOS.
PBO is off, all limits are at stock. In Ryzen master I see that PPT 142W, TDC 95A, EDC140A.
While running Cinebench R23 all-core I see temps going no more than 75C, while Ryzen master tells me PPT, TDC, and EDC are all at 100%.
With this I only get 4050 to 4100MHz - which seems to be a lot lower than the 4400-4500MHz I see in reviews on stock settings. Sure, I can increase power/current limits, or undervolt, but first I want to make sure nothing's wrong.
Even with single core, I only get up to 4600MHz, whereas reviews seem to say 4900MHz should be achieveable at stock, especially as on single-threaded load my CPU is at 70C.
Could there be some default setting on my mobo that's holding back normal stock settings?
I have 3200MHz CL16 memory, but I don't think that should reduce boost?
, I could only install the middle fan as the RAM gets in the way of the fan at the front but it seems to be keeping the temperature under control. (Side note the AM4 mounting mechanism is awful.) It hasn't passed 75C in render tests, though the poor fan is pegged at 100%.
