If you're on tonight i might join youI'm in the OCUK Discord Other Voice Channels 1 if anyone wants to join me.
12700kwhat's you system specs @Jay85 ?
Your good to go12700k
Asus Z690-I
Corsair DDR5 5600mhz 32gb
3090 ref
game is on a NVME drive separate from the OS.
I'll see if i can tonight, will have to reinstall my capture software since i wiped it when installing Win11.
Yeah might try that tonight, see if it helps though i would have thought with the Win11 scheduler it would be fine to leave them on.Wow, ok that's a good system.
Try turning off the E cores, just a hunch.
I've resorted to turning everything back to stock so no overclocks of any kind.Maybe. It depends on what is causing the stuttering unfortunately.
If you're overclocking it could easily be that but often OCing will simply crash programs, not stutter. The normal, restart the box before playing, if you have a lot of background tasks, close the ones not needed.
Have you noticed any problems in other games or benchmarks?
If you have a decent internet connection try a quick reinstall, if it does nothing at least it eliminates another possibility.I've resorted to turning everything back to stock so no overclocks of any kind.
No, no problems at all, i saw quite a lot of gains going from a 9900kf to this 12700k especially in the lows. Same goes for SC, before on a 9900kf matched with the 3090 i was barely getting 30fps at the start of the game laying in the bed, it only got consistently worse as you moved around. The 12700k is night and day in performance but of course there's always small issues that needs tweaks to get right.
The stutters are very short and quick and seem to coincide with the error codes on event viewer, so the only thing i can point to right now having googled it is anti cheat but can't for the life of me figure out why its doing it or how to fix it.
Yeah did this yesterday having realised i had installed some Win10 drivers on a Win11 install! Went through the entire device manager list and reinstalled all the drivers just to be safe.If you have a decent internet connection try a quick reinstall, if it does nothing at least it eliminates another possibility.
BIOS, chipset and video drivers all up-to-date?
Yeah thats one of the first things i did when i first installed the game, i had watched a few youtube videos on settings prior to installation so i had a jist of what i needed to do.@Jay85 go into the options and make sure you have V-Sync set to No.
I had a similar but different issue with mine. After paying the original value and getting the part sent. A few weeks later I was charged fees on an under payment of £0.11 that was clearly some sort of error - I'd paid the fee I was charged on their website. Ended up having to send a lot of emails before they finally backed down and cancelled it.
I think you'll have to keep at it until you can speak to a person who can explicitly explain why you. Looking back at my mail chain perhaps these emails addresses may be of help for you:
Payments issues: [email protected]
Import charges issues: [email protected]
Invoices issues: [email protected]
No matter how hard search I cannot find the missing six quarterly episodes since this initial oneTune into the premier episode of our new quarterly series, taking you behind the scenes on the continuing development of our epic single-player adventure, Squadron 42. Take deep dives into content and features currently in the works with the top devs on the project.
