Got a good run of it there, managed to clear 3 easy missions before going for a bit of an explore, ended up in a place called Lost and found. Dont know why but the area was off limits, I didnt have anything valuable so thought I'd have a nose about to see if there was any interesting loot. When I was approaching the building the auto turrets took out the ship, when I went inside I realised I had screwed up and only had a single mag, I got eliminated pretty quick and woke up in some weird place called grimhex? Proper rundown **** hole. Is this normal? I'm no criminal rating![]()
You will have a low level crime rating now, that's where you go for petty crime, when you get out of GH jurisdiction your crime stat will pop up.
You can get rid of it by hacking a terminal, you need a decryption key which find in most bunker look boxes, then go to a security outpost, kill the guards, which will increase your crime stat, find the security console, use the key to hack in and clear you convictions.
If you have a higher rating crime stat and you get killed you go to jail.
Yeah already experienced that, shot a friendly ship by accident ended up being arrested, worked off my sentence!
