Caporegime
- 7 Apr 2008
- Lorville - Hurston
Kind ofWho would have thought that Merc could get both cars on the podium this weekend?
Horner - Hard luck Checo, there was an issue with the virtual safety car, it should have ended earlier. But it looked like he just got the jump on you.
Horner starting the excuses now.
Oh Lewis, you did not have the drink![]()
I think he meant that means the guy you’re overtaking needs to leave space and can’t do a tank slapper across the front of you to force you to hit the brakes. (Like Perez tried)How can the rule be if your front wheel is past your opponent’s rear wheel it’s your corner. Doesn’t make sense. The sport would be unworkable!!
He was looking at Hamilton wishing he could be that coolVerstappen has a face like a slapped arse even though he's won..
F1 paranoia in full effect, lame.Let's listen in to the cool down room.
Mic's get muted.
Great....![]()
Russell was saying they were wheel to wheel going into the corner so he had the right to go for it, thing is he was nowhere near wheel to wheel at any point of the corner.I think he meant that means the guy you’re overtaking needs to leave space and can’t do a tank slapper across the front of you to force you to hit the brakes. (Like Perez tried)
1. Guidelines for overtaking on the inside of a corner:
“In order for a car being overtaken to be required to give sufficient room to an overtaking car, the
overtaking car needs to have a significant portion of the car alongside the car being overtaken and
the overtaking manoeuvre must be done in a safe and controlled manner, while enabling the car to
clearly remain within the limits of the track.
When considering what is a ‘significant portion’ for an overtaking on the inside of a corner, among
the various factors that will be looked at by the stewards when exercising their discretion, the
stewards will consider if the overtaking car’s front tires are alongside the other car by no later than
the apex of the corner.”
