Raptor Lake Leaks + Intel 4 developments
Intel's tech. documentation confirms that Intel's 13th generation is still using the Golden Cove core architecture, which explains why the IPC is the same as the 12th gen. Details here:
Essentially, it's just like how the Skylake architecture was optimised for each generation, between the 6th generation to the 10th (Comet Lake).
I wonder if they have optimised the IMC / memory controller at all, aside from increasing the supported DDR5 speeds? Ideally, 'Gear 1' / 1:1 memory controller ratio would be possible, at a lower DDR5 frequency.
It's good that we will see standardisation of DDR5 at 6000mhz and perhaps higher.
Yes that's why it's called tick-tock
It's still worth pointing out, many people tend to think there will probably be a large improvement in per core performance, with each Intel or AMD CPU generation.
Also, many generations are now just 'optimizations' rather than 'ticks' or 'tocks', as with the 7th to 10th generations, Willow Cove (11th gen), and now Raptor Lake:
I assume it's mostly due to Moore's Law slowing down, that we keeping getting optimizations instead of something new.
Optimization is what always seems to proceed a new architecture generation, when a process fabrication shrink is not possible.
It's interesting looking ahead, some of Intel's future processor generations look like they could be both a tick and a tock in effect, e.g. Meteor Lake.
Luckily, Raptor Lake still supports DDR4 systems, which will make total cost of ownership (cpu, motherboard, RAM) much cheaper than the equivalent AMD offering..
Well AMD still have the 5800X3D which trades blows with the 12900k. Only the 13900k is going to beat the 5800X3D comfortably in say 90% of titles and it's going to be a £600+ CPU lol.
Comparing the 12900k to the 3d is just a joke. The 12900k is almost twice as fast in 99.9% of workloads. The 3d should be compared to the 12700f. In which case, the 12700f is also faster in 99.9% of workloads, much cheaper, and loses by like 7% at 1080p with a 3080ti in games.
What do you mean much cheaper they both are like the same price currently
Depends on use case , if building new system would go intel
If gaming and currently on AM4 cheaper to just do CPU drop in , wouldn't upgrade if already have any of the zen3 chips would be nice jump from zen 1-2
Edit I see you meant the 12700f which is £327 point still stands if already on AM4
Not really as its a dead end platform. AM5 will offer slot in upgrades for maybe 4 or 5 generations + DDR5 coming down in price. I don't see RPL being a good buy unless upgrading from ADL
Any reason why the b660 boards are locked when using unlocked CPUs ? AMD B550 I gather was never locked ? Or have I missed something ?
Be interesting with am5 being choice of 3 boards if b650 will be locked ?
He'll say the performance will be weak so won't matter
Leaning towards getting high end board in mind I'll be keeping it for good while of course if performance and price is good compared to the competition
Based on leaks this last couple days all things look good for AMD. I really do not understand Intel changing teh socket so frequently, for me its teh biggest reason to use them. I have to Intel systems one 8 year old and teh other 5, meanwhile the only AMD4 range i have not used is teh 2*** series. For me Intel have to increase socket longevity
x3d is clearly a niche case CPU. It’s good at exactly the one thing it exits for and that’s ok.
exactly get a 12600 or 12700, probably last a lot longer than a 6 core cpu too since consoles have 8 cores and games are made for them
It has its use cases pop it in old A320 board / dropping it in replacing zen1-2 for nice gaming jump will work out cheaper but the CPU should be cheaper
Building system from scratch now no brainer going intel
Well sure but you could argue that buy any CPU in existence. Remember that 7350k 2c cpu? Yeah, it wasn't bad, it was clearly a niche CPU for playing CS go and starcraft. The 7700k? Niche CPU for playing 3 year old games at high framerate. Fx8350? Niche CPU for overclockers.
And the 3d isn't worth it over a 12600k / 12700 based on teh cost either. Especially considering it loses to 99.9% of workloads to all of these, lol
What about this use case / situation you just play games and even old A320 board / wanting to upgrade from zen 1-2 for gaming boost works out cheaper
