Don
- 20 Oct 2002
- Oxfordshire / Bucks
we've not playing in a while, but if you do start playing it, we will join you im sure, be good to get a nice squadron going
damn i need to install ED:H again, not because i am bothered on the materials, but i have not got around to seeing those yet in gameFrom what I read if you need Engineering materials then I would top up at the crystal forests before they are gone. They don't exist in Odyssey so high end elementals will be harder to get.
I haven't used up the ones a gathered before Odysseys release, Once it came out it ran like garbage in VR and I've been holding off till I upgrade.
i will google if not but does anyone have the location to hand of what would be the most visually impressive one to visit? thansk.
i havent tried it but if you are going to dont even bother with ED:O or ED:H 4.0....... stick with Horizons 3.8 (which until 9th of august is just Elite Dangerous Horizons....... it is on the 9th that the merging process starts to try to get everyone on the new build)How does this run on the Steam Deck?
From what I have seen the current Horizons version graphically runs pretty good. Odyssey version will run slower due to it being graphically more intense. But the main thing will be what the controls are like on something like a Streamdeck. I would imagine it will be a fair bit better that on console since the deck has a lot more inputs, but it won't be a HOTAS type deal that's for sure. As always youtube will probably show up someone putting it through its paces in Elite.How does this run on the Steam Deck?
I suppose then in theory you could get a HOTAS setup with that scenario, I'm guess all USB peripherals will work with the deck if you get a hub, and if you find the game to your tastes and want to play it to its full extent in that way, but yeah there are players that swear by KB+M, though I have never mastered it as once you get used to a stick it is hard to transition to anything else with this game I find.I would probably play it on the sofa with a PS4 controller to a TV...I could mix it with a keyboard and mouse?
I am actual a HOSAKBElite Dangerous contols are fantastically agnostic, and you can mix and match.
For instance, i use HOTAS or HOSAS for my ship, i use xbox pad for the SRV and on foot stuff and a combination of pad and KB/M for the UI
(HOTAS = Throttle and stick - HOSAS - twin sticks......... in my trying to be lazy i ended up typing more )
for years i used an X55 throttle and stick... then the throttle failed so i bought an X56 throttle and stick (both great controls, utterly rubbishly put together, dunno if newer revisions improve things.) my old X55 stick gathered dustI am actual a HOSAKBRight hand on stick for and left hand on keyboard. Ain't nobody no how ever parting me from my MS FF2 joystick! So with the limited buttons on the stick and inconvenient throttle, I use the KB for throttle and pretty much everything else bar pointing my ship and firing/targeting. That plus a joypad for SRV as yourself.
